I see JohnathonSwift beat me to it.
We can't really do that with the ST .10 because it's X plate is necessary for mounting. Two of the 4 bolts will all but line up with the firewall and no adapter plate. OR one can also make a plywood adapter and cut off the offending ear. This puts the motor "almost" in the stock position. Here's a bonus, the motor from the sensei is a possible "contender" |
I have a box of 4 ruined ST .10 from my flyzone switch. I figure they will hold up in this mini-contender. |
The version in the F4U is the same and mine has held up really well. So I am happy. Mike |
Ole donk's showed, today and I give it four Hee, haws out of five owing to minor wrinkles.
Hee,haw. Hee, haw. Hee, haw. Hee, haw. |
Mine arrived today. Easily the most hideous covering job I've ever seen.
Determined to shrink it up or just destroy the plane - I got out the household iron and cranked it up to blazing hot. Within 10 minutes I had every wrinkle out - including all the red. Someone described it as playing "heat gun chicken" and that's about right. It's right on the verge of melting when it finally draws up - but it will. I'll get some assembly time in soon and report back; but so far I'm pretty happy with it. |
It's definitely heat gun chicken alright! I couldn't get all the wrinkles out of the red on mine because I chickened out, lol. You will love the way it flies though. I flew mine in a pretty good breeze today along with my Mini Ultra Stick and it by far handled the wind better than the MUS. |
Finally FINALLY built my Contender with the stock hardware (I question that decision since I don't trust the wheel collars on the push rods - temp CAed them but should solder them soon). Wheel collars also get in the way of the wing bolt too. Yuck.
My electronics: EMP 35xx-1400kv motor 8x6 SF prop 30A ESC (from Millenium Master) Tactic RX (also from MM) Fylzone 3s 1800mah (also from MM) AUW - 832g Everything balances perfectly and under the watt meter seems to be within spec. Should have good power on the maiden today or tomorrow. P.S FYI my Millenium Master is still flying after 2 horrific crashes and a frankenstein-ed motor mount. Foamies are tough buggers. |
Thanks voxel, I was just going to question about balance since I wanted my RX further back instead of in the box. That sounds like a good set-up. Same battery I plan to use. I think those stock rods/collars are bulky , but they should be fine.
Checked CG and all is well with 3sx1800 all the way forward. My RX is mounted above the CG under the top canopy. |
Preliminary watt test with soggy cold battery and cheap 1000 kv motor.
9x5 prop 10.59 v x 15.15 a = 160 watt 9.2x9.47 prop 10.59v x 17.03 a = 180 watt I guess I have ran out of 9x6 GP SF props. Are most using the APC 9x6? or the GP SF 9x6? |
Thread Tools | |
Similar Threads | |||||
Discussion | TopFlite mini Contender EP ? | ltc | Sport Planes | 374 | May 30, 2016 07:47 AM |
Question | Top Flite Contender conversion | ltc | Glow to Electric Conversions | 18 | Mar 20, 2013 11:43 AM |
Discussion | New park sized Top Flite Contender | PRND21 | Classic Pattern Flying | 13 | Aug 26, 2012 11:13 AM |
Found | Top Flite Contender Kit | KaP2011 | Aircraft - Fuel - Airplanes (FS/W) | 4 | Jul 10, 2012 08:25 AM |
Discussion | Build - Top Flite Contender | safebet | The Builders Workshop | 34 | Jul 15, 2007 11:16 PM |
