Aug 02, 2012, 11:07 PM
rcmaverick's Avatar
700 mm Wing Span - Ailerons -What is the Solution?
I have a small glider HK Pearl. Great plane to fly but rather fragile. Each time I land the wings simply "break" away and even on text book landings. The wings just get clipped away by the grass. This follows by 10 minutes of re fixing the aileron servo cables and taking in the slack. This does not happen on large planes as the fuse is much larger and the wings don't touch the grass
What mod should I use?
I have thought of gluing the wing but fear a bad landing will cause more damage. I also thought of spring loading the wings from inside. BTW it already has two magnets holding it in place.
I am looking for a balance between the "breaking away" feature and the nuisance feature.
Aug 02, 2012, 11:15 PM
Wake up, feel pulse, be happy!
Piece's Avatar
I had a similar problem on my Hawk Sky, which appears to share the Pearl's wing mounting setup. I solved it by putting hole straight down through the top of the fuse and through each wing root, then slipping in plastic pins to lock them in place. It's easy to slide the pins out for wing removal but they stay solid during flight and landing. Use a hot piece of wire to melt the holes so that they're a little bit tough on the insides.
If there's room, you may just be able to use Velcro.
If you don't mind the looks, you could probably put a small hook/anchor point on each wing and stretch a rubber band between them. Maybe do one on top and one on bottom to keep the pulls balanced.
Latest blog entry: Jeti ESC resto-mod
Aug 02, 2012, 11:27 PM
rcmaverick's Avatar
Appreciate if you can post a picture on the first mod (plastic pins). About the rubber band mod wouldn't it affect the aerodynamic properties? (It would be interesting to hear which musical note this rubber band plays when in the air. )
Aug 02, 2012, 11:48 PM
Piece's Avatar
I don't have any pics of the HS on hand and I'm missing my camera's USB cord. I'll see about posting some up once the ducks are back in their row.
The rubber bands should have a negligible effect on aerodynamics. If you set it up so that they're strung tight against the fuselage between the wings, it'll be no worse that having an antenna trailing behind the plane like we did with 72MHz gear. Never seemed to cause issues.
Question f-15 118.3% 33" wing span, what prop and motor? wanna go faster Pusher Prop Jet Models 8 Aug 02, 2012 04:23 AM
For Sale HELICAM SOLUTIONS MARK IV RC HELICOPTER CAMERA MOUNT cost $2,700 Go4it FPV Equipment (FS/W) 3 Jul 24, 2012 12:34 AM
Sold 60" Mach Dart, glass version w/ full span ailerons, RTF dbarrym Aircraft - Sailplanes (FS/W) 5 Jun 22, 2012 08:46 PM
Sold P51 1600 mm wing span velyter Aircraft - Electric - Airplanes (FS/W) 1 Mar 13, 2012 02:36 PM
Sold Sale Pending MM Magpie AP (54 “ span) wing w/ailerons - $20 L P/U Roseville, CA rud-elev Aircraft - Electric - Airplanes (FS/W) 5 Jul 11, 2009 08:23 AM
