This thread is privately moderated by Jack Crossfire, who may elect to delete unwanted replies.
Jul 28, 2012, 08:20 PM
Jack Crossfire's Avatar
So it continues, after 3 years
A lot besides sonar was done in the last 3 years, but the matter of making something bulletproof for an ordinary consumer requires revisiting it. The PCB fabrication has improved, since those days.
Jumper resisters of varying sizes have replaced most vias. Where vias are unavoidable, magnet wire has replaced wrapping wire. Chip capacitors have replaced through hole capacitors. ARM has replaced PIC. Single layer boards have replaced dual layer boards. They're lighter & cheaper when home made. Upside down etching has replaced manually shaking the acid. Leaving bare board has replaced flood filling, to reduce weight. Isolating solder points with small traces has given better solder balls. Having all connection points on the edge of the board has replaced scattering them throughout the board. Soldering molex connectors directly to the board has replaced umbilical wires. 1200dpi has replaced 600dpi. Landscape mode has replaced portrait mode, because the printer warps the long direction.
3D sonar using all 4 transducers for reception is the latest experiment. Surely, all these experiments have been done & given up on, before.
Jul 29, 2012, 03:57 AM
Euphoric flights
GreenAce92_v2's Avatar
Can you explain this project any more? I picked up the words "3D sonar" specifically.
Does this mean that if you can project the image on some sort of screen that you can navigate with that screen ?
Build Log After 40 years...finishing the Electric Canberra MK62 JuanFe Scratchbuilt EDFs 44 Apr 29, 2015 07:21 PM
Discussion My CR-914 after years in storage Fokker Ace Sailboats 55 Aug 04, 2014 05:53 PM
Discussion Back after 3 years of not flying jtderr Electric Plane Talk 11 Apr 17, 2012 06:48 PM
Discussion Timing : after so much years of using BLM ..... What Do we know about timing barney 69 Power Systems 3 Oct 15, 2009 11:44 AM
Discussion I'm back on the Forum after 3 years or so.... kgascoigne Electric Plane Talk 3 Apr 12, 2007 12:41 PM
