Jul 28, 2012, 01:58 PM
robertus's Avatar
Build Log
Abandon All Hope - Chiggy von Richthofen is coming - plans
Yes. Is coming. I saw him today
Glider Chiggy von Richthofen (1 min 25 sec)
Be ware.
The Glider is flys. So maybe the big one will too.
Here is my sketchup model
Jul 28, 2012, 04:22 PM
That looks very cool. Can't wait to see the big one.
Jul 28, 2012, 07:26 PM
Zen in the art of foam
djacob7's Avatar
Great! Amazing roll stability in spite of the wing being anhedral!
Jul 28, 2012, 09:07 PM
maurice076's Avatar
That is pretty cool!Can't wait to see it flying!
Jul 28, 2012, 09:16 PM
Wake up, feel pulse, be happy!
Piece's Avatar
Odd glide it has.... It goes pretty straight and level, then stops and just falls.
Cool
Jul 28, 2012, 09:31 PM
"Fly, yes... Land, No"
OutcastZeroOne's Avatar
thing looks awesome as a glider. Now you just need the airsoft turret on the hammerhead and guns on chiggy and you can have some great dogfights
Going to do the "abandon all hope" on the side?
also, when are you going to start making kits of these things? I want one of each
also, you made me have to go buy the DVD set of the show.
Jul 28, 2012, 11:11 PM
skumgummi dave
robertus:
A little 10 gram motor and a light battery and BNC and you would have that flying perfectly!
Thumbs up;
Dave-
Jul 29, 2012, 01:17 AM
Altitude is my friend...
Depronicus's Avatar
Absolutely. It's incredibly stable. It would only need elevons for control.
That thing is pretty damned remarkable, actually...
Jul 29, 2012, 02:10 PM
slebetman's Avatar
I've seen that glide before with my tandem wings balanced close to neutral CG. What's happening is that it stalls without pitching up (like you would see with a tail heavy plane) nor pitching down (like properly balanced and trimmed planes). So it maintains attitude but just loses lift.
The down side of this mode of stall is that it's very hard to recover from. What you want is for the nose to pitch down at the onset of stall allowing the plane to gain speed and recover from the stall. This is what you're seeing when you see an airplane porpoising.
There is a solution to this if you don't want to change CG. For my tandem wings I simply use motors that are powerful enough to be able to climb out of a stall so that I don't need to configure them nose heavy.
Jul 29, 2012, 02:51 PM
robertus's Avatar
Any advice is helpful. It's an unusual design.
In the second half of the movie I moved the CG forward and to improve glide.
I think to use Emax 2812 with propeller 7x4 or emax 2822 with 8x4 prop.
Dimensions
Here is CG calculated
And tested
Jul 29, 2012, 06:06 PM
Depronicus's Avatar
Originally Posted by robertus
...It's an unusual design...
It sure is. It really looks like some sort of Imperial fighter out of the first "Star Wars" movies.
Where did you get the idea for it?
Jul 29, 2012, 09:21 PM
slebetman's Avatar
I'm really looking forward to see if this works. I've tried building an X-wing (the Star Wars fighter, not simply a plane with x wings) but failed to find a solution to spiral stability.
Due to the large forward area of the X-wing and zero vertical area behind the wing it was laterally unstable. It could be made to fly great as long as it's flying in a straight line but any attempt to turn it causes it to violently enter a spiraling spin straight into the ground.
This planform is similar but seems to be quite stable. I wonder if the spikes on the wing tips act as small canards thereby improving spiral stability. If so then there is hope for the X-wing.
Jul 29, 2012, 10:28 PM
robertus's Avatar
Chiggy von Richthofen is the best pilot of alien race from tv show "Space Above and Beyond"
It's opponent to my SA-43 Hammerhead
Chiggy von Richthofen vs Hammerheads - tv show (14 min 20 sec)
Slebetman, Try adding low vertical stabiliser, but as far away from the center of gravity. even outside the wing. Like in my SA-43.
Jul 30, 2012, 12:30 AM
Depronicus's Avatar
...from tv show "Space Above and Beyond"...
Very cool! No wonder it reminded me of a Tie Fighter.
Jul 30, 2012, 12:50 AM
caseten's Avatar
... tv show "Space Above and Beyond"
One of the best sci-fi series ever.
Discussion The Kids Are All Libertarians ... there's hope... logan5 Life, The Universe, and Politics 0 Jul 13, 2012 01:23 PM
Discussion Hope you all remember to leave a tip dll932 Life, The Universe, and Politics 101 May 04, 2012 02:47 PM
Discussion Got one of these coming..hope she lives up to the hype... J_Cunny Foamies (Kits) 1 May 04, 2012 10:08 AM
Discussion Kennt von euch jemand den PC Flugsimulator von Microsoft??? sada96 3D Flying 8 Mar 30, 2012 05:47 AM
Discussion All Hope Abandon, Ye Who Enter Here Azarr Electric Plane Talk 19 Sep 20, 2008 05:01 AM
