Jul 24, 2012, 10:57 PM
What goes up...
acuralegendz's Avatar
Build Log
Team Blacksheep Discovery Build Log !!Video UP!!
Link to Video Post so you don't have to scroll so much... https://www.rcgroups.com/forums/show...08&postcount=4
FPV GEAR https://www.rcgroups.com/forums/show...79&postcount=3
So here it is, the TBS Discovery frame. Ordered the frame from FPVManuals.com along with there Tricopter Delrin Frame. Both arrived yesterday. Also ordered 8 DJI F450 arms and a full F450 frame from UAVProducts.com. Thats 4 black and 4 white arms. The rest of the parts I already had from other builds. So here goes:
Parts List:
TBS Discovery
F450 hardware and 4 arms
4X DJI MOTOR 2212
4X HobbyKing F30A esc's flashed with SimonK
FlSky 8 Channel Receiver
Naza Controller
Stock DJI 10" props( will replace with Graupner 10")
Graupner 10" Props(Balanced by me)
All of the parts that are included:
Top and bottom plate
Header pins for Receiver and what I think for there "core" system
hardware for attaching motor to arms
Red anodized stand-offs w/ hardware
2 cables I believe for connecting your FPV camera to the board
They do not include hardware to attach arms to plates
I wasn't sure so thats why I bought the full F450 kit
A pic of the contacts that are "baked" into the board
Top plate
Black and white arms and hardware from F450 kit
First I soldered the headers on for the receiver
Next I soldered on the esc's and battery terminal
Mount the Naza with 3M Foam tape
Solder the Naza power/led module
Next apply hot glue to + contacts
Plug in receiver cables from Naza to top plate
As you can see in the previous pics I've also attached the red anodized stand offs
Affix top plate with standoff hardware and F450 hardware
Attach motors
Attach GoPro and FPV camera
Finished!! (I realized I did not have more male to male servo leads so I had to attach the receiver directly to the Naza for now.)
Hopefully I will get some video tomorrow.
Jul 24, 2012, 10:58 PM
What goes up...
Just remembered that I could turn one on its side and take up 3 channels, now its mounted at the rear, pretty cool back there!!
Also added my GPS
Jul 24, 2012, 10:59 PM
What goes up...
FPV Gear
ImmersionRC 600mw TX
600TVL SONY SUPER HAD CCD D-WDR Color Board Camera with OSD Menu DNR
5.8 GHz "TrueWired" RHCP Windmill
Ground Station
ImmersionRC 5.8GHz Uno Receiver
5.8 GHz "TrueWired" RHCP Fan
7" LCD
Vuzix 920 glasses inside Ski Goggles
3s 6000mah Turnigy Nano-Tech
HK Power Distribution Board
Maiden FPV, Boring(First ever FPV for me!!!)
Maiden FPV TBS Discovery (9 min 19 sec)
Jul 25, 2012, 12:53 AM
What goes up...
Got some great flights in tonight at the flying field. I messed up and left my GoPro on upside down mode so I am rotating the videos now. This thing is SOLID, lets see if the video tells the same story. Video up soon...
TBS Discovery Naza First test (13 min 40 sec)
TBS Discovery Second flight (5 min 33 sec)
With Graupners(10in Unbalanced)
TBS Discovery Unbalanced 10in Graupners (2 min 50 sec)
Balanced Graupners
TBS Discovery Balanced 10in Graupners (4 min 5 sec)
Jul 25, 2012, 01:52 AM
gitit20's Avatar
Not a bad little set up how does it handle compared to the normal Dji f450 frame?
Jul 25, 2012, 05:20 AM
Registered FPVer
KiT FPV's Avatar
I'm digging this frame!
Jul 25, 2012, 06:46 AM
What goes up...
Haven't flown it yet. We will see tonight!!
Jul 25, 2012, 07:21 AM
Registered FPVer
KiT FPV's Avatar
The DJI frame I just sold would have been worth hanging onto to convert into this. Can't wait to see some post flight reviews.
Jul 25, 2012, 07:25 AM
Ohhhh blue/white plastic arms. Those vibrate even more than red/white ones. DJI will never admit to it, of course.
Simonk esc + vibrating plastic arms =
DJI F450 Flame Wheel aka LameWheel vibrations FAIL (0 min 52 sec)
Jul 25, 2012, 07:30 AM
You could use a light battery or try the graupner or APC props. The added weight of the frame and FPV equipment is more likely to cause issues with the DJI stock props.
Jul 25, 2012, 07:41 AM
Originally Posted by crocus
you could use a light battery or try the graupner or apc props. The added weight of the frame and fpv equipment is more likely to cause issues with the dji stock props.
+1
Jul 25, 2012, 07:43 AM
Nice and clean build, please keep us updated
Jul 25, 2012, 08:14 AM
What goes up...
Thanks got Trappys message. I will have graupners tomorrow thanks to KitCyclic. I'm also running 4s turnigy nano-tech 3000mah and 2200mah. I will not put any fpv gear on until I have "prop-er" props. I will also be trying keda 20-20ls to see if they make a difference. Thanks for your words of wisdom.
Jul 25, 2012, 08:49 AM
What goes up...
Since I have not flown it yet, I will give you my impressions on the build. It was fairly easy even without included instructions. If you know how to solder and tighten screws you should be good to go. I'm a fan of the amount of space available when using the DJI arms,as they add some height between the plates. All of the solder points are clearly marked and there are plenty of extra spots to add your gear. The front of the frame was well thought out for holding the GoPro and FPV camera, and I was able to put my memory foam dampening between the GoPro and frame. Another nice little thing they did which will probably be overlooked by most is cut out the spot at the end of the arm where it meets the frame. Its a small detail but I like being able to route some of the cables through there(surprised DJI didn't think of that). The spot where the FC goes is marked,and the Naza was taken into consideration here so it was easy to find the "middle". Being able to move the battery forward and backwards to compensate for the CG also is great feature in a FPV frame. I will be doing some light flying this evening LOS with the GoPro running and stock unbalanced DJI 10" props to see what the video looks like. Stay tuned Timecop!(BTW my GF loves the vibrating arms...)
Jul 25, 2012, 09:14 AM
Registered FPVer
KiT FPV's Avatar
Originally Posted by acuralegendz
(btw my gf loves the vibrating arms...)
lmao!
New Product Team BlackSheep Ritewing Zephyr (ARF Kit) RiSCyD FPV Talk 43 Jun 09, 2011 06:46 AM
Discussion FPV system setup philosophies by Team BlackSheep trappy FPV Talk 919 Mar 18, 2011 02:43 PM
Discussion Team-BlackSheep.com, FPV website RiSCyD Other Websites 18 Feb 22, 2011 10:30 AM
Discussion Team BlackSheep retracts claim of having flown the furthest trappy FPV Talk 71 Nov 09, 2010 09:39 PM
Build Log 48" Team Monkey Swinger build log [email protected] Slope 201 Oct 29, 2009 05:29 PM
