Mini-HowTo
How to configure wkm alti, gps and failsafe to one 3 position switch for Graupner MX2
How to configure wkm alti, gps and failsafe to one 3 position switch for Graupner MX20 Radio.
I have the WKM failsafe, alti and GPS configured to channel 5 set to CTRL-9, 3 position switch 1: Go to settings Servo adjustment. 2: Scroll down to channel 5 "S5" Change "trv" to: 108% 105% (You will need to flick the ctrl-9 switch in order to edit the - and +) 3: Go back to settings main screen, select Control adjust, "input 5" Change offset to: +87% (Stay on this screen) 4: Still in Control adjust menu, Scroll right, (Press right arrow once) to travel. Change travel to: +81% -31%. (You will need to flick the ctrl-9 switch in order to edit the - and +) All done, on your pc running WKM software you should see all engagement highlighted to blue when switch is flicked. A lil trick I find for easy calibrating compass. 1: copy your fully configured model to an empty model block, name it some thing like DJI-cmps 2 : Edit the settings to these in the pics below When ever you need to calibrate the compass all you have to do is select this model (You may need to rebind and restore failsafe settings to the receiver from the "fail-safe adjust menu settings on the MX-20) I hope this lil tutorial helps |
Thread Tools | |
Similar Threads | |||||
Discussion | Activating 3 position switch on turnigy 9x | AliB | Multirotor Drone Electronics | 43 | May 16, 2015 08:13 AM |
Discussion | Transmitter setup - 3 position switch, camber slider or both? | Fly2High | DLG Hand Launch Gliders & F3K | 39 | Jul 17, 2012 12:28 AM |
Question | Question for Hoverfly, 3 position switch for GPS | KCV6 | Aerial Photography | 1 | May 25, 2012 10:12 AM |
Help! | how to turn on the 3 position switch for F-14 sweep wing | jet-ster | Radios | 4 | Feb 16, 2007 09:04 PM |
How to set-up a 3-Position Switch for Shutter Servo? | putt_13 | Aerial Photography | 8 | May 13, 2005 10:52 AM |
