Old Jul 19, 2012, 10:22 AM
viper522 is offline
Find More Posts by viper522
Question
FPV Sky Surfer - PNP or Kit?
I have a FPV hexcopter but I can't fly it smooth in the wind and it will be making a transition to low power 5.8GHz for visual-range camera work. My 1.3GHz gear will go to the plane instead.
So I'm looking at the Sky Surfer, wondering if I should build the kit and add a $100 hop-up motor/esc combo or buy the PNP version with stock electronics. The type of flying I expect to do is low altitude (<1000ft) sight-seeing FPV - nothing acrobatic. But it will need to carry all the FPV gear and fly about 20min. Oh, and GoPro to record HD.
Some spare parts I already have:
4x Hoverthings 1050kva brushless
4x TowerPro H40A ESC
1x Hobbywing 5V/6V 3A UBEC
2x Turnigy nanotech 2200mah 3s
3x Turnigy nanotech 2650mah 3s
2x Zippy compact 850mah 3s
5x Hyperion 550mah 1s
2x Turnigy 1800A servo 8g
1x Turnigy Head lock gyro
1x GS-1 gyro servo
I'm not in a real hurry so product availability isn't a huge concern.
Thoughts?
Old Jul 19, 2012, 11:31 AM
mklinker is offline
Find More Posts by mklinker
mklinker's Avatar
I just purchased the kit and put my own electronics in because I had a motor and a ton of servos. It looks like you will need a motor (~2000kv) and servos. If I were you I would get the setup that has both of these for simplicity sake, keeping in mind they may not be amazing parts. You can always upgrade later if you need to.
Old Jul 19, 2012, 11:47 AM
viper522 is offline
Thanks Mike!
Old Jul 19, 2012, 01:07 PM
BCSaltchucker is offline
Find More Posts by BCSaltchucker
fly by night
BCSaltchucker's Avatar
There is somewhat limited selection in motors for the plane given the low prop clearance. So maybe get the ARF model with the motor for now. Having seen his plane in action all-oem, it is still quite capable in oem form, even doing aerobatics. For my build I did get a motor relocation kit to run 8 inch prop and larger motor, which is even more fun to fly and more capable of carrying FPV gear and larger battery. Once you load it up, however, I feel the spar is insufficient, so I added a 2nd one.
Sold Sky Surfer v1 (aka Bixler)...Kit for FPV. wamdue Aircraft - Electric - Airplanes (FS/W) 2 Jul 19, 2012 10:37 PM
Wanted NIB Sky Surfer v4 or HB Bixler Kit IIIHorseman Aircraft - Electric - Airplanes (FS/W) 5 Jul 15, 2012 07:01 PM
Sold Sky Surfer (V1) new kit + FPV pod(s) Eagle-Eye Aircraft - Electric - Airplanes (FS/W) 2 Jun 01, 2012 09:11 AM
Sold SKY SURFER FPV pan/tilt pod kit... TBello FPV Equipment (FS/W) 5 Jun 01, 2012 09:07 AM
Discussion EZ or Radian or Sky Surfer for FPV? MikeSSS FPV Talk 30 Jun 25, 2011 10:15 PM
