Jul 18, 2012, 06:45 PM
New Product
Seagull Mini MXS-R Park Flyer
The Mini MXS-R is the third park flyer plane from Seagull.
LInk
http://www.horizonhobby.com/products...s-r-ep-SEAX128
Specs
Plane Type: Scale Civilian
Experience Level: Intermediate
Power Plant Size: 450-480 Electric
Recommended Environment: Outdoor
Fuel Type: Electric
Wingspan: 35.4 in (900mm)
Overall Length: 30.4 in (775mm)
Wing Area: 235 sq. in. (15.2 sq. dm.)
Flying Weight: 30.4-33.6 oz (860-950 g)
Motor Size: 450- to 480-size motor
Radio: 4-channel minimum radio system
Servos: (2) sub-micro and (3) super sub-micro servos
Prop Size: 10 x 5 Electric Propeller
Speed Control: 30-Amp Brushless
Recommended Motor Battery: 11.1V 3S 1800-2200mAh LiPo
Trim Scheme Colors: UltraCote Pearl Blue (U845), Silver (U881), True Red (U866), Bright Yellow (U872)
CG (Center of Gravity): 2-3/16 in (55mm) back from leading edge at wing root
Spinner Size: 1-3/4 in (45mm)
Control Throw (Ailerons): Low: 3/8 in (10mm) up/down; High: 1/2 in (12mm) up/down)
Control Throw (Elevator): Low: 3/8 in (10mm) up/down; High: 1/2 in (12mm) up/down)
Control Throw (Rudder): Low: 9/16 in (15mm) left/right; High: 13/16 in (20mm) left/right
Approx. Flying Duration: 6 minutes
Main Wing Tube Length: 332mm
Main Wing Tube OD: 5mm
Is Assembly Required: Yes
Assembly Time: 5-7 Hours
Nov 11, 2012, 11:51 AM
3d and EDF, some scale
MustangAce17's Avatar
Almost done with mine, a few things that aren't great like wing flex around spar but overall a nice plane. Hope to maiden later today if my local hs has the right prop adapter.
Dec 28, 2012, 02:02 AM
How did you like the mini mxs-r?
Dec 28, 2012, 03:33 PM
it was ok, but not gonna buy another, had some bad characteristics
May 23, 2019, 12:50 AM
Hello everybody,
I just bought one, construction is really light and nice (appart from the riging and fittings which are way too heavy) finishing is nice, also i don't like the paint scheme (strange aluminium drawing in front of the tail (goes off once protection film is peeled off using acetone)
May 23, 2019, 01:48 AM
the drawings on the elevator and the Seat logo should have been avoided to me.
Now for aerodynamics:
I fear the little wing, so i'll build a new wing covered with oracover (colour code 057) and silver, each half wing will be increased by 9 centimeters.
I'll build a new stab and a new rudder, the rounded trailling edges are not good for aerodynamics
May 23, 2019, 01:50 AM
MXS R EP Mods
Here are some pics of original aircraft
May 23, 2019, 01:51 AM
some more
May 23, 2019, 01:54 AM
Here are some pics of the kit i received, really beautifull
May 23, 2019, 01:55 AM
pics:
May 23, 2019, 01:56 AM
Wing modification
May 23, 2019, 02:10 AM
I will also change the wing spar holder in the fuse which is not tight enough and doesn t hold the wings as it should, i bought a 5mm int / 6mm ext aluminium tube for that purpose.
The wing profile will be 4 mm thicker than original one at wing root
May 23, 2019, 05:54 AM
MXS R EP mods
Here are the plans
May 25, 2019, 08:58 AM
Hello MustangAce17, what do you mean by "some bad caracteristics"? about the flight you mean?
May 25, 2019, 09:03 AM
New wings are nearly finished, thanks to my son who is helping me. Each wing should weight around 45 grams without covering
Discussion Seagull MXS-R aerophilia Glow to Electric Conversions 44 May 30, 2014 05:05 PM
New Product Seagull Park Flyer Nemeisis pdansalvish Parkflyers 12 Aug 25, 2012 09:04 PM
For Sale Breitling (MXS-R) 30cc Plane LPU (Seattle) laplap112 Aircraft - Fuel - Airplanes (FS/W) 1 Jun 20, 2012 11:12 AM
For Sale Breitling (MXS-R) 30cc Plane LPU (Seattle) laplap112 Aircraft - Fuel - Airplanes (FS/W) 3 Jun 18, 2012 12:24 AM
those mini r/c cars converted to those micro park flyers!! djpikey20 Scratchbuilt Indoor and Micro Models 25 Aug 07, 2005 02:09 AM
