Mar 29, 2013, 05:09 PM
Airborne whenever I can.
PAT-T's Avatar
Hi,
When will the R5 be shipped?
Pat
Mar 29, 2013, 05:16 PM
ltc
ltc
AMA 97737
ltc's Avatar
In case anyone is considering ordering any Jeti equipment, I got this email from Esprit this morning...
Up to $125.00 OFF!!! Up to $125.00 OFF!!! Up to $125.00 OFF!!!
Next 48 hours ONLY
(Expires March 31, 2013 at 24:00 EST US)
Save $5.00 off your $100.00 Order! Discount Code: 01OFF
Save $10.00 off your $200.00 Order! Discount Code: 02OFF
Save $15.00 off your $300.00 Order! Discount Code: 03OFF
Save $20.00 off your $400.00 Order! Discount Code: 04OFF
Save $25.00 off your $500.00 Order! Discount Code: 05OFF
Save $75.00 off your $1000.00 Order! (Best) Discount Code: 06OFF
Save $125.00 off your $1500.00 Order! (Best) Discount Code: 07OFF
My Hacker DC-16 glove arrived this week from HeadRC (couldn't ask for better customer service and shipping charges), so I took the opportunity to order some Jeti equipment while this promotion from Esprit was active.
(also ordered a Sebart Miss Wind 50e biplane (white/green from GravesRC .. the only one I could find in that discontinued color scheme... but that's a thread for another forum)
Mar 29, 2013, 05:18 PM
ltc
ltc
AMA 97737
ltc's Avatar
Originally Posted by SteveR
Zb, the major receiver upgrade you mentioned...is that a software upgrade that can be downloaded for existing receivers or will this only be included in new receivers?
TIA,
Steve
Originally Posted by Seasick78
Should be an update that is downloadable.
I hope it is just software. I am holding off ordering receivers until more details are available.
Mar 29, 2013, 07:17 PM
Seasick78's Avatar
Originally Posted by jotto
Bonus question: how well does the dynamic timing function work on the Mezon? Should I use that instead of a fixed advance timing value on a helicopter?
Just flew both aircraft. I set both to auto timing and they both flew very well. I can't tell if its an improvement or not, but they both flew very well and I'll be leaving them set on auto timing.
Mar 30, 2013, 05:49 AM
Yes, it is. All current updatable (EX receivers and some pre-EX) will be compatible with the major update.
Mar 30, 2013, 07:46 AM
ltc
ltc
AMA 97737
ltc's Avatar
Thank you very much.
Mar 30, 2013, 09:09 AM
Originally Posted by PAT-T
Hi,
Pat
We hope next week, FCC/IC had documents for over 10 weeks.
Zb/Esprit Model
Mar 30, 2013, 10:13 AM
I tried to update my Jeti Mezon 90 with firmsare 1.23 to 1.27. The upgrade failed with some error message that I can't remember, and now it's dead. I can't connect to the JetiBox, and it doesn't respond to stick input
When I try to update it again, it says
USB adapter o.l.
Device searching...
Device detected.
ID (39185:21802) H:0911 B:0221 S:FFFF
Error: No update data found
Update error. Try again please.
Is there anything I can to to revive it? Factory reset, force firmware upgrade or something else?
Mar 30, 2013, 07:02 PM
Zb/Esprit Model
I hope this includes the DS16 as well. Flying season is upon us...
Mar 31, 2013, 07:23 PM
Originally Posted by Puttputtmaru
Alarm for turbine shut down in flight
As a follow up to my previous post, the amp-draw information from the MU EX can be use as a flameout warning. Not always easy to hear when others are flying around you.
If the fuel pump draws 0,8-1A at idle rpm and the alarm trigger is set to <0,5A. If the ECU shut down the fuel pump (due to any reason), you get a audio warning "Warning, flameout!" (custom sound for example). Then you will know in an instant something that you usually need a few seconds, if not more , to realize.
(Thanks Feffe for the great tip)
This is great, I will add it to our Blog.
Zb/Esprit Model
Mar 31, 2013, 08:48 PM
Are you going to bring accessories for sale for the DC 16 at the Toledo show? I am looking for stick switches and harness support?
Apr 01, 2013, 04:14 AM
Are we any loser to getting a definite date for availability, through dealers, for the DS-16?
Apr 01, 2013, 11:15 AM
Sorry nothing, we have over 14,000 items In Stock. Also way too much problems with OH IRS.
Zb/Esprit Model
Apr 01, 2013, 11:16 AM
No, all the same. If your dealer put order in you are fine.
Zb/Esprit Model
Apr 01, 2013, 08:00 PM
Team JetiUSA
pvogel's Avatar
So yesterday at the field I realized I'd forgotten the magnetic key for my SPS20 power switch on my pattern plane. Not wanting to give up a day at the field and drive 20+ miles home, I decided to try using the magnetic clasp on my iPhone holster. It works!, it might even be a little easier to use than the key that comes with the switch.
I saved a day at the field and now I know I'll always have a backup to the key as long as I stick with the magnetic clasp on the iPhone holster (which I will do because, unlike velcro I can silently open the holster and unobtrusively check my iPhone at meetings, or even during dinner with my family (not that I'd EVER do that :-).
Peter+
