Aug 14, 2020, 11:10 AM
Look another addition to ever expanding Jeti/Elite family.
Now in production, brand new Elite 6-BUS Channel Expander. Get up to 6 servos (PWM) or 5 servos and EX Bus or Telemetry from single Jeti EX Bus port on your receiver.
Zb/Esprit
Aug 14, 2020, 04:12 PM
ah dinnae ken
jimbo12's Avatar
Hi-
E1 EXBUS turned out to be okay - I had a bad jumper!
Thank goodness!
Aug 14, 2020, 04:34 PM
Now in production, brand new Elite 6-BUS Converter. Get up to 6 servos (PWM) or 5 servos and EX Bus or Telemetry from single Jeti EX Bus port on your receiver.
Zb/Esprit
You are powering up to 6 servos through one socket and wire?
Aug 14, 2020, 05:48 PM
ah dinnae ken
jimbo12's Avatar
Only for bench testing.
Aug 14, 2020, 08:08 PM
Small servos not a problem, small DLG does not pull anything.
And for anything bigger, think servo is not channel/function.
Many functions do not need high current, lights, gyro, retract with extra battery .....
But we will be selling 2 types of cables, standard 6”/125mm with JR connector and
10”/250mm with silicone leads and JR signal connector.
Zb/Esprit
Aug 15, 2020, 05:58 AM
Tonight I experienced a crash which initially thought was interference related because at the time it was going down (from only about 50-100ft altitude) I heard my "warning" audible which tells me when Q < 20%. After getting home and looking at the log, I was surprised to see supply voltage dropping out prior to R1 (an R7 EX) Q dropping to 0. Voltage was supplied by an ESC set to 6.0v output. Evidently the voltage drop triggered the reboot at the "?" pointed in red. What is the voltage threshold at which Jeti receivers will reboot? My Vmin recorded was 5.76v.
Aug 15, 2020, 06:05 AM
Hi,
while the RX boots up he can't send any telemetry
Min voltage is around 3.3 I think because they work fine with 1 Lipo cell.
I think the BEC restartet.
regards
gecko
Aug 15, 2020, 10:14 AM
ltc
ltc
AMA 97737
ltc's Avatar
Strange..,
Espritmodel website https://www.espritmodel.com/jeti-dup...telemetry.aspx says 3.2V but the Jeti manual https://file.espritmodel.com/documen.../jeti-rex7.pdf says 3.5V minimum operation
Were you running a DSM or backup battery in the plane? Did they both fail?
What is the type / connection of battery wiring used?
Sorry to hear about the loss
Aug 15, 2020, 12:02 PM
ltc
ltc
AMA 97737
ltc's Avatar
PowerBox Pioneer with Jeti telemetry
Looks like a really nice alternative/replacement for the Jeti CB2xx
https://www.aeropanda.com/collection...werbox-pioneer
Built in gyro, small aluminum case, 2 BAT inputs, full Jeti telemetry (with .bin file since they mention full programming from Tx?), pushbutton or magnetics switch
Coming from Powerbox I would expect the quality to be what you e come to expect from their Powerboxes over the years
It’s also nice to see them offering Jeti telemetry support in addition to their native Core protocol
Just have to find a good plane to put one in to try !
Aug 15, 2020, 12:19 PM
In search of speed......
Dansy's Avatar
I highly doubt it would in the devices....probably just the jetibox....
Aug 15, 2020, 12:26 PM
Puttputtmaru's Avatar
You need the Gyro sat to have the gyro as I understand it and it is only one battery input:
https://www.aeropanda.com/products/p...f2f15e9e&_ss=r
If you want the Gyro in it and two battery input, you have to go to PowerBox Mercury SRS which also has power regulator in it:
https://www.aeropanda.com/collection...werbox-mercury
But even with the sat gyro it comes out to about 300 USD, sounds very good indeed depending on your needs.
Aug 15, 2020, 05:21 PM
Strange..,
Thanks ltc- it's just a foamy Night Timber so no great loss (repairable). The Avian "Smart" ESC was the last bit of of Spektrum electronics in it after replacing the BNF servos (2 of 6 had failed) and the BNF receiver (12 holds in one flight, was lucky to get it back that time). So with MKS servos and and a 2 Jeti receiver setup, what was left to fail? I should have known . I run backup power in everything larger and over the years that's saved a 2m pattern plane on 3 occasions, so I'm a believer, just didn't expect to get bit here. Another experience to learn from .
Aug 15, 2020, 06:08 PM
Balsadust Everywhere!!!!
The BEC in you ESC is to be suspected.
If set to 6.0V, voltage should stay there and not "move" that much, unless it's faulty or overloaded.
The receiver works well up to 1cell lipo (3.x V), but from you graph I suspect your ESC is just shutting down and then resetting.
Saludos,
Jean Paul
Aug 15, 2020, 06:34 PM
ltc
ltc
AMA 97737
ltc's Avatar
Still hate to see any plane lost.
Regarding the Spektrum ESC ... Spektrum and Castle Creations ... friends don’t let friends, well you know.
Aug 15, 2020, 10:17 PM
Zb/Esprit
Do you have any plans to develop a powered hub based on this product?
