Flashing Turnigy Plush(SiLabs) success, now with tutorial! - Page 50 - RC Groups
Jan 08, 2014, 09:04 AM
Originally Posted by 4712
Yes, strange. Mine is from HobbyKing. Should be similar.
Perhaps you can measure with a resistance meter D12 (PB4=Miso=C2Data) against GND? It should read the same as D11 against GND.
All unconnected and un-powered...
Both D11 to GND and D12 to GND measures same 1k.
Jan 08, 2014, 12:12 PM
Has anyone tested blheli with tigers new u5 motors ?
Having issues with simonk and are considering switching esc to some that run blheli.
Also 40-50A esc to recommend ?
Jan 08, 2014, 03:22 PM
It is important to measure with + at the D11/D12 Pin and - at GND...
But it depends very much on the meter (testing current differs).
I get here about 7.8KOhm with at testing current of 100ľA.
Please repeat the measurement with Arduino Board plugged into USB, to power it up. But connect nothing else.
I the resistance is again 1K, there seem to be some resistors somewhere terminating the lines...
Jan 12, 2014, 12:11 AM
It must be because of my cheap multimeter but It reads nothing when - probe at GND. If I put + probe on GND both reads 717R now. When usb connected reading drops to 642R.
There is no resistors connected between atmga328 and pins.
Jan 12, 2014, 04:47 AM
]Sounds quite normal...
Anyway the C2D line checking will be defused in Rev 11.1 in general, as there are no negative side effects.
Jan 14, 2014, 08:40 PM
Geoff_S's Avatar
Sorry to ask a possibly dumb question, but would it be theoretically possible to modify the firmware on these ESC's to provide telemetry data output (voltage, current, speed etc like some high-end ESC's do eg Jeti Mezon) ? I've searched but found no mention of the idea.
Jan 15, 2014, 01:19 AM
It is not in the main BLHeli repo, but has been done:
https://www.rcgroups.com/forums/show....php?t=1912368
https://www.rcgroups.com/forums/show....php?t=1907690
Jan 15, 2014, 05:11 AM
Geoff_S's Avatar
Thanks, that looks interesting.
Jan 17, 2014, 12:30 PM
lrplin's Avatar
hello all;
Has anyone use this (Hobbywing Skywalker Constant Speed ESC Programmer http://www.banggood.com/Hobbywing-Sk...r-p-89811.html) before?
Jan 17, 2014, 12:40 PM
Originally Posted by lrplin
hello all;
Works hassle free.
Does the same Job as Silabs Toolstick and fits plug and play to the Origin 10A ESC, or the Origin double ESC.
If you want to use it with a different plug, be aware that the colors are different from the "standard" colors in the BLHeli manual (red=C2CK, white=C2D,black=GND).
Color meanings of the stick here is:
yellow= C2D
black = C2CK
red = GND
Jan 22, 2014, 07:45 PM
Hi guys, just want to know if this turnigy plush 25a esc is compatible on DJi Naza m-lite fc? Is it better than Afro esc?
Jan 22, 2014, 09:03 PM
Flyingfool's Avatar
Hey guys,
Is anyone using HK 10 amp escs flashed with Blheli 11 with RCX 1804 motors having any sink problems?
I just finished a machine today and the left front end of my Y6 looks to be having a sink problem during acceleration (drop outs).
Are any other changes needed in the firmware when flashing for this combo (timing etc.) or is the default setting working fine for others?
Randy
Jan 23, 2014, 02:04 AM
Seems from many posts in RCG that this motor often causes sync problems.
Ordered one for test .
Jan 23, 2014, 03:39 AM
throw new IOPilotException();
IceWind's Avatar
Hey, I have those motors and a couple of ESC's that can be flashed to test.
Plush 6A, Plush 10A and XP12A
Quick question, I've been searching but I didn't find yet answer to this.
Is it possible after flashing to alter the settings using the servo plug? (not talking about TX programming)
I ask as I'm about to flash some ESC's and I depending on this I either wrap them in shrink tube or not.
Thanks!
Jan 23, 2014, 06:13 AM
Flyingfool's Avatar
I'm using the same motors on 2 other quads with no problems but use other brand of escs, plush 10 amp and rcx 10 amp. No sink problems with these so the motors are not the issue.
Randy
Found forget the plush, i need 5x 30 amp esc that i can flash, no plush !!! crash8384 Aircraft - Electric - Multirotor (FS/W) 14 Jun 25, 2012 04:10 AM
Discussion is it possible to flash the Flycam Blackboard w/ 4.7kk X betito Multirotor Drone Talk 2 May 03, 2012 03:12 PM
Discussion Silabs 8051 ESC (Turnigy Subperbrain) Firmware nickax Multirotor Drone Talk 2 Jan 30, 2012 12:11 AM
Sold 2 Turnigy Plush 10 amp ESCs + 1 Turnigy 5A UBEC + 1 Turnigy Programming Card - $21 shawn595 Aircraft - Electric - Power Systems (FS/W) 2 Apr 02, 2011 01:30 PM
Discussion Is it possible to convert TURNIGY Plush 30A ESC's from PWM to TWI/I2C control benbois DIY Electronics 0 Dec 17, 2008 12:56 PM
