Jun 29, 2012, 05:17 PM
Head NEAT geek
Tom Hunt's Avatar
FMS 1400mm MK9 Spitfire BASH to MK 12
Hi guys
double timing here, doing both my FMS BF-109F bash and here this FMS Spitfire (1400mm) into a clipped wing MK12.
I will be:
Clipping the tips
adding the Griffon Cowl
modifying the LG for more scale retract
proper carb scoop
proper LH underwing oil cooler
near scale Jablo 4 blade prop (spins CCW from cockpit)
new "pointy tip" rudder.
proper looking cannons
Proper "early MK" elevator horn balance
misc "nice" details.
new paint scheme
I WONT be:
making the tailwheel retract (like on MOST MK12's). I will add a scale-like MK5 type free castering tailwheel like EB-H much farther below (thanks Chad!)
Tom
Jun 29, 2012, 05:18 PM
Head NEAT geek
Tom Hunt's Avatar
clip the tips.
Started by clipping the tips. I just cut the foam, sanded, added a ply splice and some balsa to make up the TE of the tip cap. Gesso paint to harden the foam to make it easy to sand and make smoother.
Jun 29, 2012, 05:29 PM
Head NEAT geek
Tom Hunt's Avatar
pointy tip rudder constructed
1/8 Balsa core with "blue foam" outsides. sanded to taper at TE.
quick to do, more durable than just foam.
Jun 29, 2012, 05:31 PM
Head NEAT geek
Tom Hunt's Avatar
elevator mod
added 3/32 wire torque rod between elevator halves (not shown) (got rid of foam bridge)
added balsa to LE to strengthen.
Jun 29, 2012, 05:34 PM
jbc
jbc
WHO's your DADDY!!!
jbc's Avatar
I'm subbing just so I can admire your brilliant work Tom
Jun 29, 2012, 06:58 PM
Galand's Avatar
Seeing Tom's work, I am proud to also live on Long Island. A priviledge!
Jun 29, 2012, 09:29 PM
2 many planes & 2 little time
scootrb4's Avatar
I'm subscribed
Jun 29, 2012, 11:37 PM
Scale Builder
Excellent choice of subjects Tom! I love all Marks of the Spit but the Mk.XII and the XV and XVII Seafires are among my most favorite. I will definitely be anticipating your completed model. I am most likely "preaching to the chior" but since some XII's were converted on the production line from Mk.V airframes while others were converted Mk.VIII airframes some of them did retain the fixed tailwheel unit. Spitfire EB-H in the picture below illustrates the fact.
Jun 30, 2012, 05:33 AM
Head NEAT geek
Tom Hunt's Avatar
Kewl... knew that but had not seen a picture of EB-H. That will be my choice then rather than EB-D or B.
Thanks Chad
Tom
Jun 30, 2012, 09:23 AM
Head NEAT geek
Tom Hunt's Avatar
paint stripped
I stripped the paint off most of the model this morning (acetone). Here is a pic of it so far.
I also have hinged the elev/rudder and mount the whole tail (permanently).
The cowl has also been mounted, but I still need to add the blister on the top centerline behind the spinner. The MK14 (from which I derived this new cowl) does not have this feature.
Wings have been permamentlty attached with Gorilla glue at the new dihedral. Tube spar was cut at center and a nylon block made with the new dhidral angle in it.
as you can see I am running my BF-109F bash at the same time.
Jun 30, 2012, 11:05 AM
Galand's Avatar
Originally Posted by Tom Hunt
paint stripped
I hope that, in the last picture, what I see running down off the front of the cocpit hatch is not what it looks like!
Jun 30, 2012, 11:46 AM
Head NEAT geek
Tom Hunt's Avatar
no, Starbucks a good boy, he only pees in his litter or in the garden where he can kill the hostas!
Jun 30, 2012, 12:06 PM
Galand's Avatar
You raise'em as well as you bash'em!
Jun 30, 2012, 01:14 PM
Scale Builder
How did you make the cowl if I may ask Tom? In that second pic it looks 3d printed! The whole things looks spectacular as usual and is sure to be an attention grabber when finished.
Jun 30, 2012, 01:20 PM
Head NEAT geek
Tom Hunt's Avatar
3d printed!
Yup, I have axcess to one for barting engineering for parts in my spare time.
Mini-HowTo FMS 1400mm BF-109F Bash and repaint Tom Hunt Electric Warbirds 81 May 19, 2014 01:54 PM
Sold Parkzone MK IX Spitfire w/ Optional Retracts and Extra Parts -- LPO jktravis Aircraft - Electric - Airplanes (FS/W) 7 Jun 29, 2012 02:20 PM
Build Log FMS/Airfield 1400mm MK 9 Spitfire Bash to MK5 Tom Hunt Electric Warbirds 145 Apr 22, 2012 05:03 AM
Discussion Another FMS Spitfire bash FLYBOB54 Electric Warbirds 8 Jan 08, 2012 12:18 PM
Whoops! FMS/Airfield 800mm Spitfire Mk IX Maiden... Lberry.88 Electric Warbirds 12 Aug 18, 2011 03:46 PM
