This thread is privately moderated by Syberian, who may elect to delete unwanted replies.
Old Jun 22, 2012, 09:40 AM
Syberian is offline
Find More Posts by Syberian
Oleg
Syberian's Avatar
Megapirate X STM32 based UAV board
The MegaPirate X autopilot project is designated to control RC model planes, multirotors and other aircrafts, FPV aircrafts and small UAVs. It has built-in OSD overlay system.
The flight controller was built around the powerful Cortex M4 CPU and uses advanced algorithms and several types of sensors to keep the aircraft safe in the air.
Its main features are:
Extended manual control with onboard channel mixer
Aerobatic flight mode
Autoleveling flight
Two-way wireless telemetry (requires separate modems)
Computer joystick control
FlightGear flight simulator support
Multi-screen graphic OSD for FPV flights
Voice and sound alerts
Return home when control is lost
Waypoint flying
Position and altitude hold modes
Automatic takeoff and landing
Custom takeoff and landing patterns
Variometer with sound
Programmable LED controller
Telemetry-over-video
Ground antenna tracking
One-click firmware update (requires Internet connection)
Flight telemetry recording and playback in realtime using the PC software
Onboard telemetry recording (requires the X logger)
Flight logs analysis and export to processing and graphing software
Command Line Interpreter: C language programs, flight control plugins, complicated missions
Offline map browser with caching
The project site:
http://MegapirateX.com
Connection diagram:
https://dl.dropboxusercontent.com/u/...x/mpx_conn.pdf
MPX Manual (old):
https://dl.dropboxusercontent.com/u/...manual_eng.pdf
CLI manual:
https://dl.dropboxusercontent.com/u/...px_cli_eng.pdf
Flight videos:
Clouddiving (5 min 22 sec)
202418 2 (11 min 49 sec)
quad with payload (2 min 7 sec)
autonomous flight
180418-2.avi (4 min 27 sec)
Important notes:
This is NOT an open-source project.
Autopilot modes for multirotors are WIP
Old Jun 22, 2012, 03:12 PM
msev is offline
Find More Posts by msev
Cool features! Hehe are there any free samples available for poor students to beta test hehe
Could the hardware schematics be provided even though the code is closed-source..I'd really like to build it myself..
Old Jun 22, 2012, 06:08 PM
Syberian is offline
Oleg
Syberian's Avatar
msev,
there is a text description given at http://forum.rcdesign.ru/blogs/39391/blog14455.html
It is in russian though.
In 2 words: you need an stm32f4discovery, hk e-osd, all-in-one sensors board or blackvortex to solder to and a pair of resistors to pullup the i2c to 3.3v.
Sorry i have no samples at all. I`ve built my HW by myself this way and have bought all the components:
And you still need a key to enable an autopilot.
Old Jun 23, 2012, 07:17 AM
msev is offline
Very cool Oleg, I'm very interested! Very comprehensive manual, great work!
I was just kidding about the samples, I had to try my luck :P
So the chinese imu's with same sensors are also supported, that's great! Will other sensor combo's be also supported?
Can osd be configured in any way? The font and lines are too thin for me, can the text size also be slightly increased..
Telemetry will be video-based right? The decoder on the ground will be which platform? Atmega or also stm32? Could be an arduino for sake of price ..
Telemetry could be also via rfm22b (openlrs)...or the new 1W rfm which will be in the new version of olrs.
For flight with pc joystick you need two-way telemetry, can it be via openlrs connected to the computer?
May I just ask you what is the price of the SWID key? If I damage the board and need another SWID will I have to pay again (I would show photos of board)? Or can I contact you directly and we work something out.
Is receiver RSSI monitoring available? Is RTH autotriggered when receiver failsafe?
Do I need to put bootloader on the discovery board, do I need a jtag or some other special programmer or is a cp2102 programmer good enough?
For what is AT24C64 used?
Is there a chance that other osd would also be supported, I made a diy arduino based lm1881 osd
Are waypoints 3d, meaning that altitude is defined also?
Sorry because I'm asking so much, but I'm very excited
Marko
Old Jun 23, 2012, 01:28 PM
Syberian is offline
Oleg
Syberian's Avatar
Hi Marko.
Wow, that's a bunch
It is just a 1/3 of the full text. Have you seen that greyed chapters in the contents? They are still to be pulled off my brain
I`m afraid no. They have different addressing and sensors orientation. There is no #DEFINEs for the user to change.
There will be an OSD menu where you could switch on/off every displayed element. Unfortunately there is no way to increase the line thickness and font size without re-tailoring all the OSD layout. Though there will be the symbols shadow later. I hope it will look much better.
There are 2 ways of delivering the telemetry to your PC: using the video decoder (combined with an antenna tracker) or an external RF downlink. I'd say the video decoder provides much faster refresh rate.
The video decoder will be about the price of Arduino so there are no savings here Also you will get a 3A UBEC up to 42V -> 5V for your pan-tilt servos on the same board.
For joystick control you need just one-way uplink. It could be any one-way LRS capable of the serial data transmission. Using it with the video decoder you will get the kind of 2-way telemetry.
The SWID is $99.99 now. It will cost more when I will add more features in the project. Once purchased the key will last forever.
If you have your board destroyed - contact me for possible workaround.
Two times yes. There is a dedicated RSSI input reserved though I have never had a receiver with that feature. Maybe you would help me out how to do this?
There are several failsafe settings in the Autopilot Config window. See manual.
Also there will be a separate chapter about the emergency behaviour of the AP.
Do I need to put bootloader on the discovery board, do I need a jtag or some...
If you are gonna use the discovery it already has a builtin ST-link programmer. You have to put the bootloader there with any software programmer supporting ST-link. No external hardware needed except for the FTDI adapter for GCS operation.
It is an external settings storage. The STM CPUs has no on-chip eeprom.
Actually you don't need an OSD. The firmware provides its own OSD. Everything you need is to provide some circuitry to detect a video sync and mix in the OSD signal.
I.e. you can connect the OSD_SYN to your lm1881's pin #1, OSD_White connect through the diode and 180R to the video socket. Don`t forget to erase your diy-osd chip or it will spoil the signal.
All of them! also there are several types of waypoints, absolute and relative - see Mission Control chapter of the manual.
Huh! I have to add another chapter in the manual: An interview with Marko
Thanks for your questions. I hope I didn't missed something.
Old Jun 23, 2012, 05:04 PM
msev is offline
I guess I should have studied journalism hehe ..
Originally Posted by Syberian View Post
Hi Marko.
Well will they be supported, people including me prefer the cheaper chinese Imu's.
Sent you a PM with a proposal.
Old Jun 23, 2012, 10:57 PM
Syberian is offline
Oleg
Syberian's Avatar
Ok, it is possible to add the 'use cheap chinese IMU' button into the GCS.
Though I need your help to figure out the sensors orientation and addressing. Grab this imu module and PM me.
Old Jun 24, 2012, 04:40 AM
JaggerMD is offline
Find More Posts by JaggerMD
Lufträuber
Hello.
That sounds realy great.
Since i've killed my Flyduino Mega, that's the right project for my allinone.
I've ordered Discovery-Board and AT24C64 on 16. June
LM1881, GPS and APC220 i have in stock.
But what is the serial speed for the GPS-Modul?
The serial speed from my GPS-Modul is 38400 with 5Hz.
What features will work without SWID-Key for testing?
Greetings
Marcus
Old Jun 24, 2012, 05:14 AM
JaggerMD is offline
Lufträuber
Originally Posted by jaggermd View Post
what features will work without swid-key for testing?
rtfm!!!
Old Jun 24, 2012, 06:00 AM
Syberian is offline
Oleg
Syberian's Avatar
It is 38400 @ 5-10Hz.
Also the board will try to re-configure MTK and UBLOX modules working at 9600 by default: try to switch them to 38400 NMEA @ 5 or 10Hz which available.
Also I am using an eagle tree gps V4 teared off my eagle tree osd set It works without need to reconfigure.
Old Jun 24, 2012, 08:35 AM
JaggerMD is offline
Lufträuber
Is this shematic right and enough for the build in OSD?
And my GPS-Modul has only 4Hz. Is it enough?
It is a Navilock NL-552ETTL.
Marcus
Old Jun 24, 2012, 08:41 AM
Syberian is offline
Oleg
Syberian's Avatar
Marcus,
yes it is.
If you'll find the OSD symbols too dark - change the 180R to 100R.
For battery voltage measurement make a divider: battery-> 33k -> PC3 (discovery) -> 2k2 -> ground. Battery readings adjustment located in the Autopilot Config window.
For current measurement put the ACS756 100A current sensor to the PC2 port and power it from 3.3v
Old Jun 24, 2012, 08:48 AM
JaggerMD is offline
Lufträuber
Thanks.
Now i'm waiting for the STM-Board.
I'm very curious.
Marcus
Old Jun 26, 2012, 09:20 AM
JaggerMD is offline
Lufträuber
Just an idea.
Then it must be possible to add a cardreader with a at24c64-chipcard to store different settings and/or missions on different chipcards!?
But i've not found the i2c-address for these chipcards.
Marcus
Old Jun 26, 2012, 09:43 AM
Syberian is offline
Oleg
Syberian's Avatar
Why bother with hardware? I can make something like a 'config dump' in the GCS to save and restore a whole configuration in a file.
Anyway, if you are DIY the board with discovery and some kind of shielding - it is up to you to use a card instead of the chip. Be sure it has an I2C address of 0xA8 (0x54 in 7-bit space)
New Product Pirates' Productions Proudly Presents: the MegaPirate UAV and more... kinderkram Multirotor Talk 4475 Jan 08, 2016 03:29 AM
New Product zeroGravity - An STM32 Flightcontroller based on PIPO32 hardware Jessestr Multirotor Talk 40 Jun 25, 2012 09:18 PM
For Sale HoverFlyPro Control Board for Multirotor UAV's Bruce Mandel Aircraft - General - Miscellaneous (FS/W) 1 Jun 14, 2012 09:23 PM
Discussion X copter based on KK V5.5 board liftof problems riahut.com Multirotor Talk 1 Apr 07, 2012 11:41 PM
Discussion Inemo inertial module stm32 and mems demonstration board Z06 Tony Multirotor Talk 0 May 02, 2011 04:57 PM
