Airplane flying in Marin County ? - Page 3 - RC Groups
Jan 26, 2013, 11:50 AM
cheapskate extroardinairé
wind is from the west, so four corners would probably have better lift than ring mountain (closer to the coast)
Jan 26, 2013, 12:01 PM
Don't really need any specific wind on ring mtn, plus there's some concrete patches to land on for the p-47 and lots of room
Jan 26, 2013, 12:11 PM
ok, shall I see you up on ring mountain around 1 then?
Jan 26, 2013, 12:16 PM
Look, here's the runway from google earth:
Jan 26, 2013, 12:17 PM
Yeah. See you at around one.
Jan 26, 2013, 12:18 PM
Do you know how to get up there?
Jan 26, 2013, 12:33 PM
I had a look on google maps and it looks farly simple.
Jan 26, 2013, 12:34 PM
i'll give u directions.
Jan 26, 2013, 12:38 PM
ok, sounds good.
Jan 26, 2013, 12:44 PM
get directions from google to get to 196 Reed Ranch Road, Tiburon, CA. i'll give u directions from there.
ok, will do
Jan 26, 2013, 12:49 PM
I rotated the map the same way yours is, and I think i've found the spot.
Jan 26, 2013, 12:53 PM
I don't need any more directions from there, I can see how to get there. cya at 1
Jan 26, 2013, 12:55 PM
ok. when you arrive, you'll see a little path at the end of the road. take your gear and go there. once you pass a fence/gate, turn right onto a dirt path. once you get a bit farther, you should see a big rock up on a ridge. it looks far, but its really not (it takes about 10 minutes to get up). unless you find a spot that you like, go up to the rock. the rock should be in front of you or to your right the whole time, and dont get confused with the rock that will eventually be on your left behind a fence. continue on the path up the hill once you pass the rock. if you do not see the path, walk around the rock until you do. once on the path, continue up the mountain until you see concrete.
Jan 26, 2013, 12:56 PM
oh, well u got directions anyway. BOOM!!!!11
Discussion Flying fields in Los Angeles/Orange county CA Alacran72 Electric Plane Talk 21 Jan 14, 2015 10:22 PM
Discussion Marin County Flying sites NewRCer Parkflyers 6 Jan 08, 2013 09:33 PM
Discussion DLG In Marin County - Northern California Bolt55 Hand Launch 29 Apr 20, 2008 12:44 PM
Poll Poll How Many People Are Interested In An Indoor Flying Club In Orange County Ca mybitplanebitme Scratchbuilt Indoor and Micro Models 42 Mar 03, 2006 01:23 AM
