Apr 27, 2013, 03:32 PM
Home of A-10 - Farmingdale NY
boiko's Avatar
Originally Posted by Freakazoid
Shifting the weight around doesnt really change the fact that the sensors arent in the center of both axis though.
Its still on the center of roll so that probably doesnt change, but pitch might confuse the gyro's a bit.
Ahh yes the MEMS sensor would not be in the center of all axis.
As Homer Simpson would say "D'oh.."
Next time I'll think a little more before I write.
DaxFX, but still looking forward to seeing that video.
-mike-
Apr 27, 2013, 03:35 PM
Pozzix's Avatar
I put mine in the center of the top plate and full yaw command results in perfect and speedy piro.Name: ImageUploadedByTapatalk1367094795.037878.jpg
Description: Name: ImageUploadedByTapatalk1367094875.266905.jpg
Description:
I'll install soon kk2 delrin case to better protect fc.
Max
Apr 27, 2013, 03:39 PM
boiko's Avatar
Originally Posted by Pozzix
I put mine in the center of the top plate and full yaw command results in perfect and speedy piro.Attachment 5734383Attachment 5734384
Max
Max, Is your battery located on the middle plate or at the bottom of the Quad?
-mike-
Apr 27, 2013, 04:03 PM
Pozzix's Avatar
-mike-
Bottom. She flies very well and stable. Only thing is that battery is height a couple of cm than arm's landing gears but it doesn't mind. I'd like to use it only for learning acro.
This is my second flight, just to "hand shaking" me and quad
Dji F450 KK2 1.5 some test (3 min 42 sec)
I also awaiting in mail three others fc's (i.e. Naze32, Acro Naze and CC3D) just to develop some others tri/quad to try other market killers.
Max
Apr 27, 2013, 04:42 PM
AIMDROIX
DaxFX's Avatar
for the yaw,, in all my years ive never had a heli that have the gyro centered with the main shaft, my helis now have the flybaless unit all on the back like the quad,,
here is the video, just finished uploading
DJI F450, KK2 (0 min 0 sec)
Apr 27, 2013, 04:51 PM
Max
A bit expensive, but looks great.
My batteries goes between the centre plates.
Fred
Apr 27, 2013, 04:57 PM
AIMDROIX
DaxFX's Avatar
im am using 3300 3600 and 4500 batteries, so they need to be on top, they don't fit in between plates.
Apr 27, 2013, 05:01 PM
... awaiting in mail three others fc's (i.e. Naze32, Acro Naze and CC3D) just to develop some others tri/quad to try other market killers.
Max
Looking forward to some comparison reports.
Apr 27, 2013, 05:05 PM
Pozzix's Avatar
http://www.youtube.com/watch?v=t10ft...ature=youtu.be
Yeah you are right but a couple of things:
as you know medium/big helis (not Blade 130x for sure) or certain gyro brands have in their Gyro, a routine called "gyro compensation" (that automatically mixes aileron and elevator channels in cyclic system) that make pilot able to makes fast piro without (or almost) human intervention. That permits to install gyro unit in the heli's back. I don't know if KK2 has that routine :-D
I saw some video where kk2 quad makes fast piro and remains rock solid in altitude.
I'll try tomorrow to snap something about and post.
I don't try to install kk2 off center but I would, just to test if that rig has different behavior.
Max
Apr 27, 2013, 05:09 PM
Pozzix's Avatar
Fred
Wow looks great DaxFx.
I want to upgrade too...
I using 3s 3300 (13min) and 3s 3850 (16min) for now. I'd like to switch to 4s just to compare performance of Esc's (F30-A) w Simonk fw. I though that I switch props also form 10x4.5 to 8/9x 4.5 or Graup 9x5.
Max
Apr 27, 2013, 05:13 PM
boiko's Avatar
For not having the KK2 FC centered in your F450...it flew very well.
-mike-
8 bit is more fun
RC911's Avatar
Nice! Was that with self level on or off?
Below is an old video of my V-Tail with the controller mounted off-center. This was with firmware version 1.2 and no SL. Enjoy...
VC-VTail copter, autumn, 2012. (2 min 26 sec)
Apr 27, 2013, 05:16 PM
boiko's Avatar
For not having the KK2 FC centered in your F450...it flew very well. I might experiment with both locations since I'm not planning on mounting a camera. That will be for the F550..yet to be built.
-mike-
Apr 27, 2013, 05:30 PM
Pozzix's Avatar
I'll try Kaptondave. I completely abducted from quads.
Just finished to tuning my Tbs (w naza/gps) for nojello and fff flight.
Max
Apr 27, 2013, 05:42 PM
AIMDROIX
DaxFX's Avatar
http://vimeo.com/56335631
SL was on. Did you notice how hard was the wind and the quad handle it just awesome,
