Thanks again, eirikso. Best, Chris |
I am building a dji clone h550 hexa. The kk2 has no corresponding mounting holes in the frame. Anyone found a clean solution to mount the kk2 other than drilling 4 holes in the plate?
Also how much success are people having with nylon standoffs to mount the kk2? I have gyro foam and standoffs, which offers the best solution? H |
there are mounting plates for 45 degree placement.
i am using nylon standoffs on my Turnigy H.A.L frame. no problems whatsoever.. |
Hi all KK2 owners,
I have a KK2 fron HK on the way and by reading the user manual, iti seems I will have a dilema.......I plan to use the board for FPV flying with a flying wing and with a MPX Mentor, that uses 2 ailerons.... Now, the manual says that I always must plug an ESC on M1 for supplying the board with 5v.......but I will never use a ESC to the outputs , only servo's......The question is how can I power the the board ? Maybe by a separate BEC plugged into M1 ? The manual never shows wich of the 8 outputs will be used (2 of them) for flying wing usage ? Another question is that how come that the board can be used in 2 aileron servos mode, because it has only 1 aileron input........Maybe the board is acting then lik an Y lead ?, meaning that you connect 2 servos for 2 ailerons but you cannot move the separately, just togheter? Those who already bumped into such problems, please help me.... Best regards, Sergiu |
ThanksQuote:
kapteinkuk
I have been trying different settings on my KK2 board and now I have messed all the settings up . How can I reset everything back to factory settings. |
If that answered your questions.. |
D,
Please read and become familiar with the first KK post of this thread and the manual, which is also linked in the first post... Q: I accidentally adjusted the contrast such that I cannot read the screen now. Does anyone know how to do a "master reset" to default values? A: Turn the KK2 off and on again. push button 4 push button 3 (four times ) push button 4 push button 3 push button 4 push button 1 push button 3 (36 times) push button 4 Cheers, Jim Quadrocopter and Tricopter Info Mega Link Index |
good luck.. |
I just noticed that i have several square double-sided tape from a Heli Gyro that i build a while ago. Among the tapes is one rather heavy Metal plate the same size as the Double-sided tape. What is the purpose of the metal plate? and if its for changing the vibration harmonics or dampening the high frequency vibration how do you use it on the gyro?
thanks. |
That piece of metal is for Nitro Helis. You take one gyro tape, one piece of metal, and then one more gyro tape under the gyro. This will prevent some of the high frequent vibrations on a nitro heli. These vibrations can cause the heli to tip over on a FBL system. This metal is nothing you need on a multirotor FC. Truls |
See attached picture. I measure 3.99V at GND test point with respect to ESC ground. Definitely something wrong here. I hope this tells you something. Thanks!
