Nov 24, 2012, 11:39 PM
we dont NEED roads!
AcroFPV's Avatar
Originally Posted by Dharmik
I have made tutorial to set aux channel for SL. Please have a look here.
http://rcsci.blogspot.in/2012/07/kk2...nel-setup.html
Not sure what that is, but none of that is necessary to use Self Level on an Aux channel.
Nov 25, 2012, 02:34 AM
Originally Posted by jonesy40001
Set P and I gains at a level that makes you happy. if the air frame climbs when yawing reduce the yaw LIMITS. This will reduce the ammount of power available without reducing the amount of error correction at the set point.
I think this just make it turning slower, and it's pretty slow already. Of course turning slower reduces the problems I mentioned. I will try lowering it later today anyway.
As for dropping a wing, that is somthing you will need to play with in the mix editor. I dont feel comfortable with that so I used a mix in my tx to slove that issue.
Using the mixer in this case is a workaround, isn't it ? I may be wrong but I think the board should keep the airframe leveled (at any level, not just flat) while using yaw or not. I will try though. I can see the problem happening also with autolevel on but the board in this case corrects it pretty fast.
#3. descending through the prop wash will make even the most stable MR wobble, some more than others, so, slow your rate of descent or move the MR in any direction so it descends away from the wash.
Acro???
On page 1 or there abouts there is a vid of some dude playing with the stick scalling, use this with caution as it will make the MR become very aggresive.
You are right. I'll try to understand better if it happens also while travelling.
For "Acro" i meant to do aerobatic stuff, to fly with autolevel off, far, fast, you know, all those things that make you break everything
Nov 25, 2012, 05:12 AM
Falling with style
metalfred's Avatar
Anyone know why the roll servo (m7) is moving the gimbal when I pitch up / down the hex? Its working fine when I bank, but why is it trying to compensate when I pitch up / down the frame? Any idea?
Nov 25, 2012, 08:12 AM
redC5's Avatar
This works for me..
I just shim it until level and then power up...
Nov 25, 2012, 08:26 AM
srepfler's Avatar
Some weekend flight with Power meter on Hexcopter.
More power in flight then I predicted.
Power meter on HEX SIX (8 min 17 sec)
Nov 25, 2012, 08:30 AM
Registered Addict
Stigern's Avatar
Can anyone explain to me why it behaves like this?
x525 (1 min 38 sec)
I'm using the same default PI settings, and same firmware as in this video filmed when I just got my KK2 board:
X525 V3 ARF - First flight with KK2, default settings. (1 min 15 sec)
I don't get it, I've checked the motors connections, props, motor-spin direction.
Also loaded quadcopter X. Also did calibrate on a perfect flat surface.
Nov 25, 2012, 08:44 AM
C'mon Man!
georgez's Avatar
http://youtu.be/lcFkYO9x7Bc
http://www.youtube.com/watch?v=vXmD4PDuSBc
What is the difference in these two quads? Or is it the same one?
Where is the problem ?
Nov 25, 2012, 08:53 AM
Stop me before I build again!
Calibrate your ESC's.
Nov 25, 2012, 09:15 AM
Registered Addict
Stigern's Avatar
Did just do that, will do it again then.
It's the same, only different box ontop.
Nov 25, 2012, 10:10 AM
any ideas for a motor that cuts out/hiccups under load? Already checked all connectors and even swapped out bullets. Next up is to swap motors around to see if the problem follows the esc or the motor. Extraordinarily frustrating since I ordered 6 of these motors and may not even get a quad out of it!!!
Nov 25, 2012, 11:31 AM
had a mosfet in an esc that started to act up and swapped my spare motor on to the quad and moved it to every position and finally had it in close and saw the prop doing weird things on one and swapped out the esc and end of problem. Finally swapped all 4 esc's for a Hobbywing Quattro esc board and still flying the quad.
Nov 25, 2012, 12:21 PM
In my case swapping out the motor appears to have solved the issue. I was able to beat one of the two from last night into operation and its working.
Nov 25, 2012, 12:45 PM
Just in case someone else needs this...
It's a form to write down your kk2.0 settings for version 1.5
Nov 25, 2012, 01:03 PM
Grounded Pilot
IIIBonesAirForce's Avatar
Originally Posted by Acit
Thanks guys for the help, sorry that I'm not aware the ESC Calibration function had been removed from the Menu.
I did follow the method and also watch the video but both beeps from my ESC giving 2 beeps even the confirmation beep.
After Armed the board, the 2nd motor (I'm on Quadcopter X mode) is not turning even when the throttle is at max. The rest of the motors turning fine.
Could it due to improper calibration of ESC?
I would suggest you increase the minimum throtle to 20%. It worked for me after I encountered the same issue.
