Nov 11, 2012, 05:08 AM
Originally Posted by vivazapata
About donation: I would rather donate via PayPal directly to Rolf, but have not found his PayPal e-mail account.
It can be found in this thread.
Fred
Nov 11, 2012, 08:19 AM
tfmccull's Avatar
Hey all,
Just upgraded to 1.5 and I wanted to re-calibrate my ESCs. I follow the procedure and instead of calibrating i get "Throttle pass-through" on the display and it does nothing. Any ideas?
Nov 11, 2012, 08:32 AM
Del-Dredd's Avatar
Throttle pass through is what KK2 did with original FW for calibration as well.
Just message has changed I guess.
Did not bother with an ESC Re Cal after flashing to 1.4 on my Tri, still works fine as on 1.2,
ESC Cal should not need re doing unless you replace an ESC or the TX.
Nov 11, 2012, 08:37 AM
Heli and E-Plane
Originally Posted by magic_marty
Worst day of my life today...lost my mother in a bad car accident, she was taking things to the good will to donate and somebody hit her head on trying to pass somebody...insted of them hitting the brakes they floored the gas trying to get around and didn't make it and hit my mother head on doing over 70 mph...i am so heart broken i can no way put it in to words...
tell your mother you love her everyday cause it might be the last time you get to...i didn't get to ..
Very sorry to hear about your mom, my condolences to you and your family.
Nov 11, 2012, 08:56 AM
Akcopter's Avatar
That's really awful news man.!!..I cant really express my condolences In words and am trying hard to do it justice....I feel sorry for your loss..but all I can say is R.I.P. @Magic_marty's MOM.....Atleast a page of this thread can be dedicated to this.....
Nov 11, 2012, 08:59 AM
KeiTora's Avatar
RC Osprey
Originally Posted by HappySundays
Hi, have a look at OpenAero2 for your Osprey project using the KK2.
OE2 has many more mixer options both on the RC side and the motor side.
You can also switch stability and/or autolevel on/off via a variety of methods.
Full thread over here.
Thank you for teaching good information!
I installed OpenAero2.
I'll be able to save the weight of over 30g.
This is a very good firmware for my purposes!:D
Nov 11, 2012, 09:24 AM
Good points ... but ...
Change tx or rx will nor require to recalibrate esc, sine esc are controlled by kk2.0 board
Yes only change one esc (still it will need a new esc same as the others), it may require esc calibration
Some esc don't need to be calibrated ...
Nov 11, 2012, 10:15 AM
Registered Addict
Stigern's Avatar
Looking forward to getting my board to to test in my x525, I just can't figure out what's wrong with the kk 5.5 I'm using now. Motors behave weird when applying throttle. And it gives more power to the left back motor, so it tilts left forward when trying to liftoff.
I've dobechecked all motors and its all according to manual :-/
Nov 11, 2012, 10:24 AM
Originally Posted by Fidy$Trainer
My KK2 board came with a Peizo buzzer attached to a connector. Where does it plug into the board?
Ok Thanks to Suburau? I saw the diagram and found where to attach the piezzo buzzer. In the video he solders on the jst connector to the back side of the board. I'm using a 4000mah 3c with a big T60 connector which attaches to the powerdistribution board on a F450 DJI board. I'm missing something someone help me fill in the missing gaps. If I attach my battery directly to the controller then what's attached to the power distribution board? Does anyone follow what I'm saying. Sory for all the noob questions
Nov 11, 2012, 10:34 AM
Hi, just run the red wire in the video to the positive side of your power distribution board, no need to worry about ground that is taken care of through plugging in your esc.
Nov 11, 2012, 10:42 AM
Thanks that's what I was looking for.
Now what about if I wanted to hook up some LED's or orientation I bought some LED's from HK and would like to plug them up. Can I use the KK2 Controller Board to hook these up?
Nov 11, 2012, 10:46 AM
DroneWorksUSA.net
flohio117's Avatar
Originally Posted by LittleG
Surprise, surprise...
Welcome to the club... You definitely have to upgrade to Firmware v1.4.
Yeah I have no clue what fw is on it right now lol. I'm waiting for my friend to get his cable in so we can update our boards.
Auto-level works awesome!
Originally Posted by Eastcoast78
When you say you missed with it,,you mean you messed it up? what does it do when you turn on auto level? and you say old firmware? which? Don't get mislead by thinking a flash well fix your problems... cause i can tell you AL works in all FW..yes the newest may make it level out faster, bottom line is AL works on every FW.
No I don't think I messed it up. When I put it into al it jousts moves around the sky trying to lvl itself but its slow then it fixes itself and starts drifting another way trying to lvl itself again. I'm pretty sure my p gain is 125 or 130 and my I gain is 50 or 60. It deff doesn't auto lvl like my CC board. But it's rate mode flies fine.
I want to get the auto lvl to work fast bc this is going to be my sport aerobatic tri and I need to have al working incase I lose orientation.
Nov 11, 2012, 10:54 AM
jsmith285's Avatar
Under Self level settings
What does the ACC roll and pitch settings do?
Can they be used to tweek self level drifting?
Nov 11, 2012, 10:56 AM
Use your power distribution board, just make sure you have the correct resistor for your voltage/ led. From HK they may already have resistor in circuit.
Nov 11, 2012, 11:02 AM
BNUC-s
biggles uk's Avatar
Is this too much I gain? I've got I and P set around 170 it flies great when you don't fly agressivley but when you gun it it does this. turn it up and listen for the nice crunch at the end thankfully only a broken motor mount and prop
hexcopter crash (0 min 29 sec)
