.....yeah...... it is right now realy great,but with an gimbal funtction (hexa + gimbal) it will be unbelieveable....
supershadow25 |
After being VERY happy with your modified software I am asking - are you going to modify the latest software along the lines you are suggesting here? as I do get drifting myself. Ted |
KK2 Self-level problem
Updated to 1.3, calibrated acc, went flying, take off with self-level, all ok, pretty stable, turned it off, flew 5 min, decided to turn it on again, in moment KK2 did hard flip to left and crash
Seems it still works, one button missing |
Oh no!!! Does it smell what it looks like?
too bad!!!...as newbie... i am staying strictly on v1.2 and with no SL at all...!
v 1.2 here as well and no problems other than a little right yaw .self level works fine .
stick with what works guys ,no need for the latest greatest firmware .1.2 works fine . the ones having most the issues are the ones switching over to 1.3 .i installed this kk2.0 in place of my free flight board and it was up and running with no issues (after doing the basics ) .just been so darn windy and rainy lately i only got a half dozen flights thru it before the weather went bad .looks like tuesday might be nice . |
OK, so after flashing my board to v1.3, it is still doing the same thing. When lifting off, my tricopter wants to flip over to the right. I got all the values to zero on the reciever test which took all of my subtrim and regular trim to do.
With the props off, the left motor (M1) spins up really fast and then at and above half thr, the other two sound to spin up to the same speed? I put the props back on and adjusted the trims so that it almost lifts off the ground level, but when doing so, the values in the receiver test are far from zero. Is there any way to re-calibrate the receiver test so that I dont have to use all the trims to get to 0? I am using a Spektrum dx6i with ar6200 receiver on the tricopter delrin kit from fpvmanuals with ntm28-36 750kv motors. |
i agree 1.2 works just fine,even better with some Abusemark Escs.
Go back and start over since this behavior is not firmware related, it's improper setup. Factory reset, ESC calibration, load motor layout, receive trimmed ( 0 and stick movement registers correctly ) and triple check that your motor layout is correct and your servo is moving in the right direction. Then try hovering with default PI values before attempting tuning.
