This thread is privately moderated by Brosol, who may elect to delete unwanted replies.
Jun 16, 2012, 12:30 AM
Brosol
Brosol's Avatar
V911 Clone BNF
Update: So it seems new V911 Clone BNF and parts may be from the same company that makes the JC 9C002 Solo Pro Clone.
The head does not have a feathering shaft.
But good news regarding binding to a 9x Tx.
Firecabbage V911 Clone Yellow BNF
http://www.aliexpress.com/product-fm...lesalers.html#
Banggood V911 Clone Yellow BNF
Yellow V911 4CH 2.4GHz Single Blade RC Helicopter With Gyro BNF
http://www.banggood.com/Wholesale-V9...f-p-46299.html
Indoor flight of the new BNF Yellow v911 single blade Helicopter - heli supplied by Banggood (1 min 44 sec)
V911 Clone Pics & Info by KKDDMM:
KKDDMM: https://www.rcgroups.com/forums/show....php?t=1674254
KKDDMM: http://plaza.rakuten.co.jp/ringmaker.../201206200000/
Originally Posted by KKDDMM
I checked the NEW V911.
It can bind with my FS-TH9X-B,and there is no problem at test hover.
So I dont regret.
But......I think this heli is not a product of WL-TOYS.
Swashplate and rudder and maingear is just! just! just as same these of 9C002(Jiuchon)!!!
(But mainblade and linkage and head is different from V911 and 9C002.)
Off course,RX is a new one,
and speed of servo-moving is very quick as V911,
but an angle of movement is smaller than V911.
Obvious advantage is below two parts.
1)swash plate(have 2 pins)
2)skid(it has new batt holder,enclosed type)
New receiver ---> yes(only main motor is used connector)
New rotor head ---> yes(but almost same)
New main gear ---> 9C002
New main motor ---> not checked
New swash ---> 9C002
New swash guide ---> at center
New buckles ---> ???
New tail fins (maybe just cosmetic) ---> 9C002(rudder)
New tail motor ---> not checked
New main bldes ---> yes(but almost same)
New tail boom ---> yes(little shorter than V911)
New bushing ---> ???
New Canopy ---> yes(cop of 260A ?)
New connect links ---> yes(but almost same)
New main shaft (looks like carbon fiber?) ---> yes(carbon)
New balance bar. ---> yes(weight is different)
Thanks!!! to KKDDMM for all the FC V911 Clone bnf info work:
Unknown:
- no CA glued parts
- no more flybar strikes?
- main motor thrust
- durability
Firecabbage V911 Clone Parts Info:
Ribble: https://www.rcgroups.com/forums/show...&postcount=712
Firecabbage V911 Clone Swash with main shaft pivot ball
http://www.aliexpress.com/fm-store/1...recabbage.html
http://www.aliexpress.com/product-fm...olesalers.html
Possible Pros:
- cheaper than SP 270A swash
- main shaft pivot ball
- long shaft hub arms but don't know length vs stock V911, SP 270A hub arms
- cheaper source for upper hub/pivot ball transplants
- weigh less than CNC metal & XTreme Solo Pro swash parts
- two swash pin angle positions for use on other frames...9958
Firecabbage V911 Clone CF Rod Main Shaft
Pro
- lighter than metal main shaft
- reduce heli weight
- increase flight times
Firecabbage V911 Clone Canopy
- Clone of SP 260A canopy so has a lower profile but weighs more:
KKDDMM: https://www.rcgroups.com/forums/show...54&postcount=2
Firecabbage V911 Clone Rx
http://www.aliexpress.com/fm-store/1...wholesale.html
KKDDMM: https://www.rcgroups.com/forums/show...19&postcount=1
Features
- 9x Tx compatible
- plug n play main motor connection
- possible plug n play battery skid connection
- possible tail motor overcurrent protection
Jun 17, 2012, 01:38 AM
Nice investigative work there Brosol, I was wondering about that Yellow one. I didn't expect that many of "our" requests were being implemented, and if the Yellow BNF has most of them... must have!
Especially since my first gen. White/Red V911 has been flown hard, and parts aren't easilly replaceable on it... so this Yeller one will be a perfect replacement methinks.
Jun 17, 2012, 01:50 AM
Brosol
Brosol's Avatar
If true, it would make a great spare parts BNF with all the upgraded Ver parts.
Jun 17, 2012, 03:09 AM
Brosol
Brosol's Avatar
I like to see a review & parts compatibility list between Yellow V911 Clone BNF? & updated WLToys V911 vs Benma Helios 100 for building more Franken hybrids.
Jun 17, 2012, 12:20 PM
Brosol
Brosol's Avatar
Regarding the yellow V911/Clone? BNF.
I already ordered it last week.
Perhaps I will receive it tomorrow.
Originally Posted by Brosol
Cool, maybe you can confirm things such as does the new Ver head use a feathering shaft, 9x Tx compatibility....other questions in my blog.
Jun 17, 2012, 02:04 PM
Crash and learn
Though a minor player in the V911 "New Version" parts lineup, do not overlook the Connect Buckle. There is a reason to stock a different part. In this case it could mean the distance from the swashplate to the flybar is also different caused by other improvements to make it fly better.
New version V911-04 Connect Buckle
Of course it could simply mean a re-designed stronger part.
Jun 18, 2012, 02:38 AM
Brosol
Brosol's Avatar
Some clues that the new V911/Clone? BNF and parts may be from the same company that makes the JC 9C002 Solo Pro Clone.
Jiuchon 9C002, a Solo Pro clone?
SoloProFan: https://www.rcgroups.com/forums/show....php?t=1444808
Frank_fjs: https://www.rcgroups.com/forums/show...75&postcount=3
Frank_fjs: Jiuchon 9C002 Swash with 2 phase pins
Jun 18, 2012, 02:39 AM
Brosol
Brosol's Avatar
Daryoon: https://www.rcgroups.com/forums/show...postcount=6910
Originally Posted by Daryoon
Wasp09: It clips on. So during crashes, it can unclip. Or partially unclip and bind up the rotor.
Anybody else note the swashplate pin and it's guide is now in the center. And the swashplate has pins for both the old position and new? Like the first Solo Pro clone, the Jiuchon 9c002.
I wonder why this change was made? It makes me wonder if they implement the center ball on the swash like the Jiuchon heli.
Originally Posted by FCMan
yes from the same factory, but this my idea for them. i hate glue .
Jun 18, 2012, 02:50 AM
Brosol
Brosol's Avatar
FCMan: https://www.rcgroups.com/forums/show...postcount=6897
New BNF
easy to repair the tail now
Jun 19, 2012, 02:16 AM
Brosol
Brosol's Avatar
Update: Banggood's description has been changed to "Yellow V911 4CH 2.4GHz Single Blade RC Helicopter With Gyro BNF" implying its not a WLToys heli.
No Banggod spare parts for the Yellow V911 Clone BNF yet.
Jun 21, 2012, 05:11 AM
Brosol
Brosol's Avatar
Preview Benma Helios 100 vs Firecabbage, Banggood Yellow V911 Clone
http://www.banggood.com/Wholesale-Be...o-p-47798.html
http://www.benmahobby.com/english/to....asp?id=58015B
Video
http://www.youtube.com/watch?feature...&v=cCqsoqo2H74
2.4G 4CH Single Propeller R/C Helicopter with Gyro (5 min 19 sec)
Benma Helios 100 Review
jameschen072: https://www.rcgroups.com/forums/show....php?t=1661845
http://www.benmahobby.com/english/toysShow.asp?id=58015
jameschen072:
Aaron qin
Aaron qin: https://www.rcgroups.com/forums/show...&postcount=188
Aaron qin: https://www.rcgroups.com/forums/show...&postcount=190
Firecabbage, Banggood Yellow V911 Clone BNF
Jun 21, 2012, 10:39 PM
Brosol
Brosol's Avatar
More Yellow BNF Clone Info
https://www.rcgroups.com/forums/show...48027&page=605
Mag718: https://www.rcgroups.com/forums/show...postcount=9066
Mag718's V911 Rx, Yellow BNF Clone Rx
KKDDMM: https://www.rcgroups.com/forums/show...48027&page=605
KKDDMM's Yellow BNF Rx
Jun 25, 2012, 01:33 PM
Brosol
Brosol's Avatar
Benma FX056
Originally Posted by erdnuckel2
Mr.Brosol posted a link to Benma in the Beetle/quadcopter thread ... and me after clicking it, I started browsing around there a bit, and here is what I found ... (no idea if there is already a specific thread for it, but mażbe its still kinda unknown)
... and judging by the pictures that could be a HECK of an interesting addition to the micro FP market ...
http://www.benmahobby.com/productsho...pst=1001001001
What you guys think ??
http://www.benmahobby.com/english/toysShow.asp?id=FX056
I noticed it too. Not much info about it. Would like to know if the Rx is 9x Tx, FlySky protocol compatible.
jameschen072: https://www.rcgroups.com/forums/show...&postcount=105
FX056 2 4G 4CH Single Propeller RC Helicopter RPC143046 (1 min 28 sec)
Jun 25, 2012, 03:38 PM
Brosol
Brosol's Avatar
GT 9016 Single Blade RC 4 Channel Helicopter
GT 9016
UPDATE: KKDDMM confirmed no 9x Tx compatibility for the GT 9016. ;(
Interesting placement of the tail motor high up on the tail fin & 2-3 blade tail rotor props.
http://www.aliexpress.com/store/prod...529933357.html
http://www.gt-model.cn/eng/Product_Show.asp?id=198
Sold Gaui Flybarless Head with NEW Mikado Balanced Swash Driver - Price Drop $49.50!!! SpeedVision Aircraft - Electric - Helis (FS/W) 1 Mar 22, 2010 08:22 PM
For Sale Brand New complete CNC head w/flybar,swash and shaft Z06 Tony Aircraft - Electric - Helis (FS/W) 8 Dec 26, 2008 05:28 PM
Sold New Microheli Blade CP All Metal Head w/ Swash badbill Aircraft - Electric - Helis (FS/W) 1 Jan 05, 2007 09:41 PM
