Jun 11, 2012, 09:42 PM
ESC Slowing down?
Had a crash of a plane and thought all the electronics were fine. However when I use the ESC at full throttle after a second the motor starts to slow down like I am throttling down. Eventually it winds up at about 1/3 throttle.
I did test with more than one motor and battery.
Anyone see this behavior before and if so think the ESC is shot?
Jun 12, 2012, 11:45 AM
Dude, I do fly all day long!
rcalldaylong's Avatar
The only thing I'd make sure is that you aren't maxing the ESC's max amp rating. Some ESC shutdown or cut out, perhaps that one slows down. I'd also make sure I eliminated all other factors, like ESC/Tx throttle range...etc, swap rx...
My only other experience close to that one is when I was replacing the heat sink on the ESC and manage to burn out the ESC somewhere. At 3/4 throttle was fine, but at WOT, it would start cutting out, then slow down to about 1/2. Yep, it went to the garbage.
Jun 12, 2012, 11:49 AM
Tried another Rx, same, only drawing 10.1amps on a 20 amp ESC.
Haven't tried resetting throttle range yet.
It does get to full throttle though, just doesn't stay there.
Jun 12, 2012, 01:35 PM
DS
DS
DS's Avatar
The only time I had an ESC slow down was when I went from 3 to 5 servos.
The BEC probably overheated and the ESC reduced power to the motor (to compensate for heat dissipation ???).
Going back to 3 servos made the problem go away.
Maybe the heatsink on your ESC has loosened as a result of the crash.
Have you tried motor/ESC only, or have you multiple servos connected to the RX as well?
Jun 12, 2012, 01:56 PM
Motor and ESC only. I'll cut the heat wrap off and see it it got knocked loose.
If it's an easy fix cool, if not it's too cheap to trouble over (Hobby King Super Simple ESC)
Jun 12, 2012, 02:18 PM
HK SS...oh gawd! throw it away already!
Jun 13, 2012, 03:34 AM
Zero Expo
typeRA's Avatar
Plug a servo into the throttle channel and watch the movement with application of throttle. This will show if the problem is the ESC or the radio system.
Jun 13, 2012, 06:50 AM
It's the ESC. Last night I tested and it got way too hot running a motor even at half throttle. Guess is it was damaged in the crash.
Help! Swashplate Tilt slows down motor speed (?) omster Electric Heli Talk 1 Mar 27, 2012 01:28 PM
Cool I think our motors are slowing things down Flyextreme High Performance 1 Mar 09, 2012 08:13 PM
Discussion How do I slow down on throttle/rudder/evelator trainer? AndrejaKo Beginner Training Area (Aircraft-Electric) 15 Mar 06, 2012 02:56 AM
Question How to slow down my RAM flashing lights? seair Night Flying 0 Mar 05, 2012 11:37 AM
Discussion Weird! ESC Actually Slows Down With Higher PWM? Help! trianta2 Electric Power Systems 6 Nov 02, 2011 01:47 PM
