Walkera V120DQ02 Disassembly - RC Groups
Jun 08, 2012, 06:17 PM
Hello,
I just received my Walkera V120DQ02 helicopter. Somehow the assembly was not good so when I first turned on the power, one of the swashplate's screw came off so the blades broke along with some other parts. I want to remove the fuselage to replace the broken parts and having a hard time removing it after removing the screws. Did anyone by chance able to remove the fuselage? If yes, could you post a step-by-step instruction so I can do mine?
Thank you in advance for your help.
Alex
Mini-HowTo What Are the Proper Settings on the WK-2603 TX with a V120DQ02 Heli? screamernyc Micro Helis 1 Feb 24, 2012 12:10 AM
Help! Walkera V120DQ02 Won't Lift-Off After Minor Crash! screamernyc Micro Helis 1 Sep 06, 2011 12:20 AM
Discussion Walkera V120DQ02 - where to connect LED lights? Debugger Micro Helis 14 Aug 24, 2011 08:10 PM
Discussion Walkera V120D02 and V120DQ02 wlee1017 Micro Helis 2 Jul 11, 2011 06:41 PM
Discussion Walkera V120DQ02 kmm77 Micro Helis 2 Jul 08, 2011 07:25 PM
