Oct 27, 2019, 04:56 AM
Seppo is there a way to send frsky s-port data over one of the gipo ports on the 900x ?
Nov 30, 2019, 12:39 AM
is there away to get rdf900x to report RSSI to ardupilot on the cube
Nov 30, 2019, 09:02 AM
gromitvt10's Avatar
Originally Posted by Seppos
Hi Everyone!
It has been a very long time since updates on things that we have been working on.. Where do I start?!?
RFD-TXMOD finally released! ... JR Style module with 900 MHz RC passthrough and Wifi for telemetry, all on a single RC controller!
http://store.rfdesign.com.au/rfd900-...mitter-module/
We got this one out slowly into the field to get as much feedback as possible to make it as good as possible it has been in use for several months and is working well.
There are also bundles available for these.
RFD900x :
We have a few variants of these modems now available!,
RFD900x Original, unlocked modem with all existing parameters settable.
RFD900x-US : FCC Certified! FCCID 2ADLE-900x, IC: 24610-900x. Also suitable for Brazil, South America. http://store.rfdesign.com.au/rfd-900...-fcc-approved/
RFD900x-AU: AS/NZS 4268 Approved in Australia http://store.rfdesign.com.au/rfd-900x-au-modem/
RFD900x-NZ: AS/NZS 4268 Approved in New Zealand (watch for link on store very soon)
Firmware wise, we have also been busy! -- more detailed update coming tomorrow. - Especially for multi-vehicle capability.
and..... RFD900ux (pilot runs being built at the factory at the moment) - more info coming soon
Seppo
Seppo,
Hi, any progress on getting a module that will plug directly into a Futaba 14SG? Thanks
Kyle
Dec 01, 2019, 06:04 PM
Ditto on the 14SG question. Is there a connector from the RFD900x to the Futaba 14SG? IS there a list of existing radios that there are connectors for?
Dec 14, 2019, 12:38 PM
kiosk's Avatar
I continue to struggle with high noise levels (90-120) on my pair of rfd900x... Have tried so many things, different settings, antennas, wrapping them up with foil, not using USB of any sort, etc.... But no luck... I didn't have this issue w my previous RFD900.... Any advice?
Sent from my SHT-W09 using Tapatalk
Dec 14, 2019, 05:31 PM
gromitvt10's Avatar
Anybody know the answer to this?
Dec 14, 2019, 06:08 PM
are you using the 2 x 2dbi antennas
Dec 22, 2019, 06:05 PM
kiosk's Avatar
u have tried 2, 3 and even the really long 9dbi ones
Feb 26, 2020, 05:04 AM
Hello, a question, can someone tell me, that Delay has the PPM Radio signal? How much delay can be expected in the Radiocontrol remote control response?
Can a Radio Control Plane be flown without FC assistance?
Thank you.
Mar 07, 2020, 07:23 PM
Purdue Engineering
Rocketman1092's Avatar
Thank you.
I use PPM over RFD900x in an FX-79 wing. While it does have a flight controller, I've flown it in manual mode a handful of times without issue. Latency is probably a bit higher than "conventional" R/C gear, but not enough to cause problems in most cases.
Discussion Range of 2.4GHz RF Modem? GuerillaFilm FPV Talk 1 Apr 18, 2013 06:06 PM
Discussion 12ch Radio relay for wireless long range UHF ground station i3dm FPV Talk 0 Mar 22, 2012 03:20 AM
Sold Short Range - Long Range ! 2x Lawmate receivers, 1x 1000mw VTX & 1x 50mw VRX crashtested FPV Equipment (FS/W) 7 Mar 11, 2012 05:32 PM
Discussion Radio Frequency for Long Range? AeroWRX FPV Talk 3 Feb 13, 2012 11:36 PM
