Dec 14, 2013, 04:54 PM
Sirach 6:7-16
CN I Dawg's Avatar
RFD900u Connector
Hi Seppos,
I was thinking of taking up your offer of 10% off and getting a RFD900u but I could not tell if it came with antennas. It appears it is not SMA but MCX connector so I don't have any pre-exisiting stuff on hand. Do you sell the connectors or cables?
Please advise...
Regards,
Steven
Dec 17, 2013, 10:32 AM
Hello Tnug,
The RFD900u can be used as both Air and ground module. If you choose the appropriate cables, it can plug into the autopilot, or into an FTDI cable.
Cheers,
Seppo
Dec 17, 2013, 10:33 AM
Hi,
The modems themselves don't come with antennas. We have the interface cables in the cables section that allows connection of the u.fl to RPSMA bulkhead. Then any existing antenna, or cable can screw into the bulkhead connector.
Cheers,
Seppo
Originally Posted by CN I Dawg
Hi Seppos,
Please advise...
Regards,
Steven
Dec 25, 2013, 10:56 PM
Dodgy Cable
Just wanted to echo this comment:
"I had a problem with the FTDI cable too (could have been driver related). I happened to have a spare cable, and the modems connected up fine."
After mucking around for two hours yesterday with an array of computers and drivers. No luck.
I dug up a cheap usb FTDI board and after some quick pin to pin connecting....all good.
Cheers
Dec 28, 2013, 12:58 PM
i just to see this great topic
i would like to know if a europeen vers will be available in a near futur???
because here, it s the the frequency of cellphone so it almost impossible to have a unit working well without lots of noisy
Jan 03, 2014, 10:15 AM
Waypoint Collector
TNug's Avatar
Originally Posted by Seppos
Hello Tnug,
Cheers,
Seppo
Seppo,
Thanks for the reply. Happy New Year!
I know you are having some delays with RCLink. I hope it is still progressing. Assuming it is, will the RFD900u be compatible with RCLink too? I noticed the early images posted showed the RFD900 piggybacked to the RCLink v1.2 board.
Regards,
T
Jan 26, 2014, 03:16 AM
Micro Boat Forum Founder
boredom.is.me's Avatar
Would there happen to be anywhere in the US that carries these?
Jan 26, 2014, 03:46 AM
Jeff at Event38 carries the RFD900 bundle:
http://www.event38.com/ProductDetail...uctCode=RFD900
Jan 30, 2014, 07:24 PM
Is there any way to link 3 of these together? I'm working on a project with a repeater quad, that follows above at 500 ft. It would be nice to send the GPS location of the lower quad up to the repeater, and ultimetly back to me on a laptop groundstation. I already have two of the RFD900s that work great!
Feb 27, 2014, 02:35 PM
Does it matter which antenna goes where? I'll be flying in pretty open areas so I was planning on using a 3dBi and a 2dBi on each RFD.
Nevermind,
Using both 2dBi on the plane.
Mar 12, 2014, 05:32 PM
I finally got my custom cases for the RD900. They fit great! The case just makes it look complete. Do not take my word for it. See for yourself.
See all pictures here:
https://www.rcgroups.com/forums/show...postcount=9039
Mar 12, 2014, 05:34 PM
An Aussie in Chicago
I will be 1st to ask.
Where did u get them?
Mar 12, 2014, 05:40 PM
I designed and printed it. Are you interested?
Mar 12, 2014, 05:45 PM
I'm interested so far?. More details.
Mar 12, 2014, 05:59 PM
If I was to sell it as a kit, it would be as follows. What I is the very first prototype which happens to be very close to perfect.
2x Top Case Half
1x Plain Bottom Case Half
1x Bottom Case Half with mount holes
6x Stainless Steel Button Head Bolts
Price would really depend on how many are made at once. I would ideally be able to sell for $25. But a solo order would be much more.
Discussion Range of 2.4GHz RF Modem? GuerillaFilm FPV Talk 1 Apr 18, 2013 06:06 PM
Discussion 12ch Radio relay for wireless long range UHF ground station i3dm FPV Talk 0 Mar 22, 2012 03:20 AM
Sold Short Range - Long Range ! 2x Lawmate receivers, 1x 1000mw VTX & 1x 50mw VRX crashtested FPV Equipment (FS/W) 7 Mar 11, 2012 05:32 PM
Discussion Radio Frequency for Long Range? AeroWRX FPV Talk 3 Feb 13, 2012 11:36 PM
