Nov 30, 2017, 05:46 AM
Kit Manufacturer
coreman's Avatar
Noontime BluFO/BluFO-XL demo in flight
Noon Demo BluFO Gaggle NEAT 2017 (3 min 14 sec)
Nov 30, 2017, 05:47 AM
Kit Manufacturer
coreman's Avatar
Rob did an amazing job lighting his BluFO-XL for night flying at NEAT
Rob Kallok BluFO XL night flight solo (DSLR) (8 min 35 sec)
Jan 30, 2018, 11:10 AM
Kit Manufacturer
coreman's Avatar
Nicholas Turner got a BluFO for his #TCCSS (The CrashCast Secret Santa) present this year and after building it with his family's help (note the paint job) got to maiden it just recently and shared a composite video from the first three fights
RA Cores BluFo Flights 1 through 3 Clips (3 min 58 sec)
Feb 03, 2018, 02:06 PM
Nice looking plane. Flies nicely too!
Jul 24, 2018, 09:04 AM
You're killin' me Smalls
BrownEyedFool's Avatar
Originally Posted by stangrob
I've been flying mine with a 2212-10 (specs close to yours) with a 1500 3s pack. I believe I'm using a 9x6 prop but can check later. This combo gives a great mix of decent speed but still solid punch off the line. Mine is built for sport and night flying.
Forgot to mention flight time. I think it's rough 6-7 minutes depending on how hard I'm beating on it
Rob
Found this relative to our discussion. Think this is a Suppo class motor, which oddly enough is also the Turnigy D2826 1400kv motor. Which I have one that I had gotten for a mini skyhunter but may not have enough stones for my taste in that.
Rough count of LEDs in your standard size BluFO?
Let me know what prop you use when you get a chance?
When you cut back the edge of EPP you said you cut small indentations in the edge of the cut foam to make pockets for the leds. what do you use to make those pockets? Was thinking an old soldering iron tip or a ball end carving bit on a dremel might work well.
Jul 25, 2018, 08:06 AM
Nice BluFo build & video!
Build Log MarkaZ 450 -micro full fuse 3 Ch Parkflyer-WITH VIDEO AND BUILD LOG !! Markus A. Foamies (Scratchbuilt) 31 Mar 27, 2016 11:24 PM
Discussion 55" Cessna 182 Parkflyer - Scale Build sam-smith Scale ARF/RTF 8 Dec 31, 2011 03:52 PM
Cool Micro F-5/T-38 Parkflyer Build boingk Pusher Prop Jet Models 2 Oct 17, 2011 10:58 PM
Build Log 51" Parkflyer Build, Flight, and Onboard Crash Video Thread Idriveaboxster Foamies (Scratchbuilt) 11 Oct 07, 2011 05:14 PM
