BluFO Parkflyer Build Log - Page 29 - RC Groups
Aug 23, 2016, 07:03 PM
Here to just enjoy the hobby
Rhea's Avatar
Originally Posted by cflchurch
I have had my kit for a few weeks and building it slow trying to find the perfect paint job with no luck. . . . . .
What ever your paint scheme be sure to make the top and bottom distinctive.
Latest blog entry: All things that fly.
Aug 24, 2016, 04:01 AM
Kit Manufacturer
coreman's Avatar
just something simple done with painters tape before final assembly
Latest blog entry: BluFO-XL review by Tim...
Aug 28, 2016, 09:11 PM
Mexia Izonfia
MetroGTi's Avatar
My favorite motor for this plane is the EMAX CF2812 1600kv Outrunner. It can be found online priced in the $8 to $12 range.
My preferred prop is either an APC 7x5 or 7x6. They give from 7 to 10 minutes of flight from a 1300mah pack depending on throttle use, with the 7x6 giving the faster top speed.
I just finished building a couple new BluFOs, one from model plane foam, and the other from Jim's EPP kit. I tried a new color scheme on them, and was pleased with the way they turned out.
- Joel
Nov 30, 2016, 10:48 AM
Kit Manufacturer
coreman's Avatar
One of my recent customers bought an unpainted EPP BluFO kit at a swap meet I attended and said he was going to airbrush it. He showed me pictures of his previous work and I was amazed and asked him to send me the final results. Here is what he did. So awesome Paul!
Apr 20, 2017, 11:21 AM
Bought mine at the Toledo show and just started assembly.
Instructions say that the bevel for the elevens should be on the TOP SIDE of the fuse. I'm used to putting the bevel on the BOTTOM.
What have others done?
Thanks!
Apr 20, 2017, 11:56 AM
Rhea's Avatar
Bottom.
Apr 20, 2017, 02:47 PM
McSkies's Avatar
Thanks!
I did the top by accident. Still flies great, just needs a little more servo travel.
Apr 20, 2017, 04:21 PM
Kit Manufacturer
coreman's Avatar
I think the idea is to put the flat part of the joint on the side with the servos so on the bottom
Apr 29, 2017, 10:21 AM
Ah! That makes sense. I'm used to putting servos on TOP of the wing, so I generally have the bevel on the BOTTOM. This design has the servos UNDER the wing, so you put the bevel on TOP.
One more question: Could not figure out where the hatch magnet is supposed to go, or what it's supposed to stick to?
Thanks!
May 03, 2017, 02:45 PM
I Look, Listen, and Learn
Timbo383's Avatar
Thanks!
Here are two pics that should explain where. They are from the water version but should be the same here.
May 03, 2017, 04:19 PM
Kit Manufacturer
coreman's Avatar
Thanks!
There is a piece with a hole in it you squeeze one into and CA. For the hatch proper I slit it from the rear and slide it between and once I am sure the orientation is right, I CA that in place, usually clamping it with some plastic bag until it sets. Basically centered in the rear of the hatch
(sorry, I was in the hospital from friday night until Yesterday at Noon)
May 03, 2017, 04:49 PM
O Boy! Hope all is OK w/ you now!!
Did the maiden flight this afternoon -- perfect! What a great flying plane.
You really did a FINE job on the design.
May 04, 2017, 05:23 AM
Kit Manufacturer
coreman's Avatar
I just did the EPP iteration Joel (MetroGTI) Did the initial design. There is an XL (150% version) being introduced at Joe Nall this year
May 04, 2017, 09:12 AM
I really like how the carbon fiber "triangle" makes the thin, floppy EPP really stiff! I've used the CF rods as re-enforcement before, but never glued in the flat ribbons like you have in the kit. Nice design! Light, but rigid.
May 04, 2017, 04:57 PM
Kit Manufacturer
coreman's Avatar
Thanks. We are hoping it transfers well to the 150%
Build Log MarkaZ 450 -micro full fuse 3 Ch Parkflyer-WITH VIDEO AND BUILD LOG !! Markus A. Foamies (Scratchbuilt) 31 Mar 27, 2016 11:24 PM
Discussion 55" Cessna 182 Parkflyer - Scale Build sam-smith Scale ARF/RTF 8 Dec 31, 2011 03:52 PM
Cool Micro F-5/T-38 Parkflyer Build boingk Pusher Prop Jet Models 2 Oct 17, 2011 10:58 PM
Build Log 51" Parkflyer Build, Flight, and Onboard Crash Video Thread Idriveaboxster Foamies (Scratchbuilt) 11 Oct 07, 2011 05:14 PM
