BluFO Parkflyer Build Log - Page 2 - RC Groups
May 19, 2012, 11:48 PM
Mexia Izonfia
MetroGTi's Avatar
The firewall is a 1.5" x 1.75" square of 1/8" thick lite-ply. It is glued in place with hot glue or epoxy.
The Emax motor had an extra long shaft, so I cut a little over 1/4" off the shaft.
May 19, 2012, 11:49 PM
Mexia Izonfia
MetroGTi's Avatar
The pushrods were made from CF rod, music wire and heat shrink.
May 19, 2012, 11:50 PM
Mexia Izonfia
MetroGTi's Avatar
And the battery and RX locations.
May 20, 2012, 12:15 AM
Mexia Izonfia
MetroGTi's Avatar
And a shot of the finished model.
She came in at 11.82 oz RTF,
May 20, 2012, 05:03 AM
gpw
gpw
“There’s no place like Foam”
gpw's Avatar
Very NICE !!!
Latest blog entry: Lost plans
May 21, 2012, 03:34 AM
Ground-Attack!
Martin@ul.ie's Avatar
Any Video? How does it fly? Land? Roll?
Jun 03, 2012, 04:41 PM
Mexia Izonfia
MetroGTi's Avatar
Sorry, no video yet. I need to find someone with a better camera.
She flies great. At full throttle she zooms along like she's on rails, but she can slow way down and almost hover at high alpha. She rolls like crazy at high rates, files as good inverted as right side up and outside loops are as tight as inside loops.
We've had been using them for combat, but have started pylon racing them as well. Friday evening we had a mid-air coming around one pylon and I went straight in at full bore creating a very graphic representation of the term "crumple zone". The crash happened just before 8pm. After dinner I cut of the old nose off and built a new one. After about two to three hours of actual work, she was ready to fly again.
Jun 23, 2012, 07:58 PM
Mexia Izonfia
MetroGTi's Avatar
This isn't the greatest video (camera phone) but here is a couple clips from our impromptu pylon racing.
BluFO Pylon Racing (4 min 32 sec)
Aug 10, 2012, 11:58 PM
Mexia Izonfia
MetroGTi's Avatar
More video:
BluFO Parkflyer foamie (5 min 1 sec)
BluFO Parkflyer Onboard Video (4 min 49 sec)
Aug 14, 2012, 11:44 PM
Mexia Izonfia
MetroGTi's Avatar
Another video...
BluFO Parkflyer "Air to Air" Video (5 min 38 sec)
Aug 20, 2012, 04:49 PM
I think it's time to fly.
Rhea's Avatar
White—BluFO
Here are a couple of pictures of my interpretation of Joel’s BluFO from his CNC cut version. It’s the same as his original but it’s all “tabbed-and-slotted” for easy assembly. Thanks Joel! It goes together very nicely. Maiden flight tomorrow.
David
Latest blog entry: All things that fly.
Aug 21, 2012, 08:24 PM
Rhea's Avatar
Maiden Flight
OK. Exceed Rocket Series 2210, 1200Kv motor with a 9x3.8 prop will move the BluFO fast enough to fly . . . . . . . at full throttle. Since that’s the only prop I had on hand suitable for this motor it’s what I used. After a stop at the LHS I have a few others. 8x6 will be the next one to try.
Even with the 9x3.8 it will climb and with the suggested starting throws as my hi-rate settings it does some pretty snappy rolls. Can’t wait to see this thing go with the 8x6.
I didn’t have enough distinction between top and bottom either. Working on the solution for that.
It was a lot of fun the first time out. Looking forward to lots of more fun flights.
David
Aug 22, 2012, 05:53 PM
My plans are in my blog
Rusty-Gunn's Avatar
Nice looking plane.
Sep 02, 2012, 08:07 PM
ab amicis auxilio parvulo
Aerospacer's Avatar
BluFO Lineage
I am one of the Team BluFO club builders that Joel referenced earlier in this thread. Our ships have met in the skies over Montissippi Park many times and are still around to do battle again. As the attached photo shows, we had built a number of examples of BluFO's and probably violated some sort of non-proliferation treaty our government has with some other country.
Sep 02, 2012, 08:19 PM
Aerospacer's Avatar
BluFO Inspiration
Joel was inspired to come up with his design after I took some liberties with the original Blue Foam Wonder which itself has been around for sometime. He both stylized it even more and developed a better flying aircraft to boot.
In the the second air video, you see glimpses of my BluFO as I am pursued around the field by Joel.
Build Log MarkaZ 450 -micro full fuse 3 Ch Parkflyer-WITH VIDEO AND BUILD LOG !! Markus A. Foamies (Scratchbuilt) 31 Mar 27, 2016 10:24 PM
Discussion 55" Cessna 182 Parkflyer - Scale Build sam-smith Scale ARF/RTF 8 Dec 31, 2011 02:52 PM
Cool Micro F-5/T-38 Parkflyer Build boingk Pusher Prop Jet Models 2 Oct 17, 2011 09:58 PM
Build Log 51" Parkflyer Build, Flight, and Onboard Crash Video Thread Idriveaboxster Foamies (Scratchbuilt) 11 Oct 07, 2011 04:14 PM
