May 07, 2012, 02:57 PM
sweeteye's Avatar
Build Log
Scratch Built M100 Micro Plane
Here are some screens of the frame work for the M100 as I call it....Ready to mount the electronics and cover the wing...built from 0.8 and 0.5 mm carbon fiber rods and foam.Has a 10.5 inch wing span and 8.5 inch fuselage.....
May 07, 2012, 03:08 PM
"Free" in Christ! #F3P
Free's Avatar
NICE!
What's your targeted AUW?
Free
May 07, 2012, 03:30 PM
sweeteye's Avatar
Thanks!....My apologies....I am not familiar with the abbreviation. wing loading?..I am a bit of a novice with specifications....for electronics I am using plantraco's. starter set three,,,,
May 07, 2012, 05:34 PM
Free's Avatar
Sorry, AUW stands for All Up Weight, basically the Ready to Fly Weight.(RTF)
Free
May 07, 2012, 07:10 PM
sweeteye's Avatar
Not sure how it will end up weighing in.....Kind of winging it...so to speak...
May 09, 2012, 06:01 AM
sweeteye's Avatar
Model is basically finished now...Shortened the fuselage to 5 1/2 inches to allow for the actuator wires to reach the receiver....Covered the surfaces with cling wrap and holographic foil....Ended up having to resolder the actuator wires at the connectors....probably why I am not getting them to function....may need to try soldering them again....motor is running and I could do a short powered up test flight....
May 10, 2012, 10:42 PM
sweeteye's Avatar
Another days effort.....went over model again...added a king post and upper and lower wires...Motor is working and rudder....elevator actuator not functioning yet...Center of gravity a bit far back due to short leads from the actuators...might have to add ballast until I can put in longer lead wires or modify the tail a bit..Ready to test fly after slight adjustment to wing and tail feathers..and the winds to calm down...
Idea Need some ideas for first scratch built plane please masonjee Foamies (Scratchbuilt) 4 Apr 12, 2012 05:39 PM
Discussion scratch built micro Dr.1 - Richtofen's No. 152/17 dcwwcp Scratchbuilt Indoor and Micro Models 28 Mar 16, 2012 10:53 PM
Build Log 2nd Scratch built plane ever! nickwasp Foamies (Scratchbuilt) 0 Feb 27, 2012 03:14 AM
Idea Ultra Micro, Ultra Simple scratch built newbie project.. will it fly? leo.geo Micro Ready-to-Fly 3 Oct 11, 2011 06:30 AM
Help! NEED HELP scratch built plane with micro mosquito eletronics. simo10 Micro Ready-to-Fly 5 Nov 11, 2006 01:33 PM
