May 06, 2012, 08:17 PM
May 07, 2012, 05:40 AM
The PIPE's Avatar
I've GOT that unbuilt Telly-40 kit only meters away from me here at home...
Dear Cherokeenut:
The PIPE Here, early on a Monday morning...it's my VERY LAST week of business college coursework, with one online course completed (retailing principles) and one online course to do the final exam on sometime between Wednesday & Friday (personal finance) later this week...there's ONLY the final exam for that online course to complete (all but one of my classes HAVE been online only!) and then I'll be GRADUATING on June 1st with my associate's degree in business administration.
I've been unemployed for just over 3-1/2 YEARS now, and a new college degree should get things going properly to be working full-time once again, the sooner the better!
Well, since I DO have that unbuilt Telemaster 40 kit, I went over to it, pulled out the rolled-up fuselage plan and carefully measured the CG "target" distance behind the wing's leading edge...
...it's got just about a 4-7/16ths inch (112.7 mm) distance from the leading edge of the wing to the CG "target" marked on the plans.
I'm simply hoping that THAT is what you were looking for...
...hope it helps!
Yours Sincerely,
The PIPE....!!
May 07, 2012, 08:54 AM
May 07, 2012, 09:07 AM
AMA 537620
ChillPhatCat's Avatar
A lot of people, me included get lazy and just balance planes on the spar for the first flight. If you keep the CG to about 25-30% of the chord you will pretty much always get a stable plane.
May 07, 2012, 11:37 AM
May 07, 2012, 12:28 PM
AMA 537620
Originally Posted by cherokeenut
Thats what I always do, but reading about the Telemaster and it's unusual elevator I understand that if you balance on the main spar then it will be very nose heavy. I've not run into this before. Every other plane I have balances on the spar, and like I say the telemaster Sr plans appear to be that way too. Pipe do you know why the Sr. and the 40 would be different?
True, it does have that lifting tail doesn't it? With a lifting surface in the back rather than just a neutral stabilizer, it will tend to act a little more like a tandem wing where you would just balance between the two surfaces.
May 10, 2012, 12:58 PM
In my plans for the Tele 40,it states the cg on the spar. I built mine in 1998.
You can't mess up too much on that plane anyway. I fly mine a bit tail heavy,but it doesn't make much difference,just a little floatier on landing.
May 10, 2012, 02:42 PM
May 15, 2012, 09:40 AM
brentg's Avatar
I picked up a telemaster 40 that was built in '85, it was never flown after it was expertly built. I have changed to a tail dragger and swapped out the K&B 40 for my Enya 60 4 stroke. I need to know exactly where the CG is, the manual says look on the plans but I can't find any on line. I find one source that says 4 3/8", another says 5 3/4", I'm sorry but that's just too much of a variable. So please help me out guys, what is the correct CG?
Cherokeenut,
I have a Telemaster 70 Arf which is 40 size Tele built in the late 80s early 90s, I to was confused about the different opinions about the proper cg, The pipe also helped me with this as well Jason from Hobby lobby, with the teles lifting tail design I used the 40% formula and it worked just right, I would never put it that far back on my own. Below is a link to the original inquire to Hobby lobby about this, my wing was a little smaller in width than the standard kit size.
https://www.rcgroups.com/forums/show....php?t=1514406
Good luck with your tele they are wonderful flying planes.
Brent
May 15, 2012, 12:03 PM
May 16, 2012, 04:04 PM
Feb 25, 2013, 01:43 PM
license to fly!
zebtqb's Avatar
i have a telemaster 40 i got from someone with no instructions did that CG work for you?
Feb 25, 2013, 07:57 PM
Build Log Telemaster 40 Deluxe Build pwhavens Electric Plane Talk 72 Jan 30, 2016 10:39 AM
Help! Cg help!!!!! Help me!!!!!!!!!! cale10 Electric Plane Talk 8 Mar 30, 2012 07:48 PM
Sold WTS Telemaster 40 - LPU - NE Ohio scottypotty Aircraft - Fuel - Airplanes (FS/W) 4 Mar 25, 2012 08:29 AM
Sold Telemaster 40 Kit kg4min Aircraft - Fuel - Airplanes (FS/W) 1 Jan 30, 2012 06:19 PM
Found Telemaster 40 kit [fuel] kartooo Aircraft - Fuel - Airplanes (FS/W) 1 Nov 21, 2011 04:24 PM
