Is it olso capable to lift a gh2 with four moto ?
1) 4 Motors MK3638
2) 4 HobbyWing FlyFun 40A 3) Hyperion 5000mAh 4) WooKong M 5) Bec 7.5A to power up the Servos 6) 2x Power HD 3688HB Digital Servo 25g/2.8kg/.07sec 7) 2x Turnigy Mini MEMS AVCS Gyro & Program Box 8) Panasonic Lumix GF3 9) GoPro HD 10) RC Immersion 600mw 11) PinWheel Antenna The motors in the pictures are the old ones and not enough to lift 2.5Kg.. and more, i will be around 2.8Kg at the end. i replaced with 4 MK3638 that have a trust of 2200gr each, so we are around 800gr each to be safe.. and 3.2 kg totally. It depence from the Props and i asked suggestions for that and i will get some 12" APC and Graupner. |
I tried with old motors and empty setup and i feel very unstable and strange behaviors.. i will try to mount the IMU in the Frame, no problem to put it upside down? |
Just for your reference you must not mount the IMU upsides down, if you look at the pic it's the right way up but underneath!
The IMU needs to be mounted on the frame, not on the damped part of the Ecilop where all the other components are sitting. This vibration damping is good, but it would (and it will as I already tested) confuse the IMU.
So simple solution for a solid performance -> IMU to be mounted on the frame. best regards Ferdinand |
@Brombo,
Is this your first multicopter? If so, I would recommend only to assemble the copter without the cam-part and get the WKM up and running. Then you should practice all the functions of the WKM to feel save and comfortable when flying. If you have gained confidence, then I would be a good time to install the camera part. best regards Ferdinand |
lol ty, but i know something and i pilot basically in FPV, obviosly the picture was just to know the total flight weight and to see the final setup even if is not finished yet. ty for suggestions anyway |
Latest blog entry: Solar powered drones: flying wing,...
That's worse than the Yamaha Rmax accident a few years ago (was in South Korea too). |
if just just rubber, a lot of people are using these things to get the vibration away from the sensors...ok there is a lot more weight involved on the ecilop system, would the FC swing more then a few millimeters? |
Thread Tools | |
Similar Threads | |||||
Discussion | Five easy piece f-14 tomcat | bobdaeronort | Foamies (Scratchbuilt) | 80 | Oct 25, 2012 05:43 PM |
Discussion | Easy Glider VS Easy Glider Pro (what's different?) | MkFn | Electric Sailplanes | 7 | Nov 17, 2011 08:42 PM |
Discussion | Spring Easi* in NZ | harrys one | Aerial Photography | 8 | Nov 14, 2007 02:22 PM |
