Mar 02, 2013, 04:41 PM
↓↘→ + (punch)
theKM's Avatar
Originally Posted by TTRotary
Jim says "board will run on anything over 3.7V". That to me means this is absolute minimum voltage, so I don't think you want to power it with 1S Lipo: nominal voltage is too close to this value. 2S LiFe seems perfect, even if it is wasted power from an electrical efficiency standpoint. Jim?
Will be LiFe for me regardless for safety and battery longevity reasons.
I'll be adding a deans connector and will be throwing in 2S lipos... easier for me to charge, have plenty of them around if I need 'em.
Mar 03, 2013, 12:13 PM
You don't want to run a switching regulator in anything that has an RF output. No matter how much filtering you do, you can never get rid of 100% of the harmonics.
The board's power connector is a two pin JST (the red ones). I happened to have a bunch of those setups for my foamies (3DHS of course!)
Mar 03, 2013, 10:56 PM
Rangers Lead the Way
Perfect, that's what I use. Will this board be user-installed, or do you recommend we send you the radio Jim?
Mar 04, 2013, 12:10 PM
The replacement boards will be just like a PC motherboard... you open up the case, unplug the connections, unscrew the original motherboard, replace it with ours, plug in the connectors, close the case...done! The antenna can be ran through the top or used with a module port.
I don't think anyone is going to need to send in their radio.
Mar 04, 2013, 12:14 PM
Fly inverted, it's more fun.
tholmes345's Avatar
Sounds great. When? Oops, didn't mean to say that.
Mar 04, 2013, 12:24 PM
j_whitney's Avatar
Jim, you said somewhere that the reason you have the standard 2.4 antennae is because no one believed that the 1-inch antennae "hump" actually worked - does that mean that on my module for the 9Z I can remove the 2.4 antennae off the back? I guess a range check would answer that question . . .
Mar 04, 2013, 12:35 PM
Airplane Killer
SumthinsFishy's Avatar
I've been trying to understand how a retrofit board can just drop into a case, and have everything fully operational. Different Tx's have varying interfaces, different displays, different numbers of input buttons, may or may not have a touchscreen. How can you account for all the differences without having it feel shoehorned into place?
I hadn't really considered going the retrofit route until the other day when you said you'd just as soon just make boards, and I got thinking how nice an A9 might be...
I'd always figured the programming fit would be best with the case you are using, and doing the major development with.
Thanks!
Dave
Mar 04, 2013, 02:43 PM
↓↘→ + (punch)
theKM's Avatar
Thanks!
Dave
The core stays the same, swap out the interface code for the system. Tx's are still just a collection of switches and pots. The programming should be very similar for the XPS3216, 9C and 9303 (all being click-wheel style), the touch-screen interface change of the A9 would be a little more involved maybe as the screen artifacts change. Ultimately, only Jim knows deep down how modular his code is for the programming parts with respect to display/interaction...
Mar 04, 2013, 03:34 PM
The board needs to be a copy of the original one (shape, connectors etc.), with new logic. Maybe production costs are low enough these days to make this happen. Time will tell
Mar 04, 2013, 05:27 PM
Bama3Dr's Avatar
I'm just curious, I've seen the pics of the new transmitter, but haven't used a transmitter with the type of selection buttons for the programming like this one has. Is the 4-way pad to the right of the screen a rotary type selector or is it just a 4-way arrow pad (sorry if I'm not using the correct terminology)?
-Dustin
Mar 04, 2013, 07:01 PM
Last year I forgot to install the antennae on my XPS Hitec Optic 6. I was flying a .25 sized nitro plane and I took off, turned left to crosswind and then left again to down wind staying in the pattern. I then turned to left base and half way before I was going to turn to final the plane dove straight down and crashed. On the way out to pick up the pieces I was trying to figure out what went wrong when I glanced down at the transmitter in my hands and noticed the missing XPS antennae. Mystery solved! Probably, if I had turned the transmitter to one side or the other, I might not have lost signal, but oh well, not the first time I have done a stupid thing in this hobby . Destroyed fuse forward of the wing, but after almost tossing the plane in the trash, I decided to rebuild it and it is now flying again. That is the only time in 3 years of using XPS equipment that I have even had a glitch.
SpadCat
Mar 04, 2013, 09:42 PM
j_whitney's Avatar
Thanks SpadCat
Mar 05, 2013, 01:38 AM
Great. Can you tell us where you think pricing would fall for this?
Mar 05, 2013, 01:57 AM
NO!! The original modules had a small stubby plastic antenna enclosure. That was replaced with a screw-on type connector. The original stubby antenna is gone on the board, so you MUST use the external connector w/antenna.
Mar 05, 2013, 01:59 AM
Thanks!
Dave
The case doesn't matter. With replacement boards, ALL transmitters would then have the same programming. The interface would be basically the same (based on the display size).
Sold XPS 2.4GHz JR Transmitter Module (9x) az_heliguy Aircraft - General - Radio Equipment (FS/W) 19 Apr 04, 2012 11:07 PM
For Sale Hacker / Spin 170 Controller, XPS Pro Dynamax, 15S 6800 XPS packs in 3S bricks. penceaviation Aircraft - Electric - Jets (FS/W) 9 Oct 13, 2011 07:55 AM
Wanted XPS 6800mah 65c 6s want to trade for xps 5000mah 65c and will pay difference sherlockshah Aircraft - Electric - Batteries & Chargers (FS/W) 3 Oct 12, 2011 08:30 AM
For Sale 3s xps 5000mah 65c $60 shipped with warranty also 2s xps 5000mah 65c $45 shipped with sherlockshah Aircraft - Electric - Batteries & Chargers (FS/W) 2 Sep 24, 2011 12:48 PM
Sold TransMitt transmitter bag / warmer**price drop** aerosheldon Aircraft - General - Radio Equipment (FS/W) 5 Mar 31, 2011 12:40 PM
