Jul 22, 2012, 08:10 PM
Lipo Burner
dcame002's Avatar
Originally Posted by Bravo47
Some people in this thread are using wing skids which may protect better than tape for a pavement landing.
Link- https://www.hobbyking.com/hobbyking/s...idProduct=8703
Tape will probably wear off after the first asphalt landing. I wore out half of the skids I added with one runway landing. Big skids are probably best
Jul 22, 2012, 08:39 PM
ancora imparo
jj604's Avatar
If you use long servo extension cables in place of the Y lead supplied you can do this and turn the box it came in into a transport box. Just trim a bit off the foam insert at the tail end and the assembled fuselage will go back in the tray it was delivered in. Cut slots in the outer box and add a cardboard protection ring for the tail , a velcro closure and you have a sturdy travel box with handle already fitted!
Unscrew the wings, pull the aileron wires through a bit and drop the fuselage and wings back in the spaces in the box where they came from. Done in seconds and nothing disconnected.
John
Originally Posted by SkyBug
An easy way to handle the Zephyr for transport or storage:
I unscrew the wing bolts, pull out the aileron cables an inch or two. Then I can have the fuselage along the wing, making it easy to load the Zephyr into the car (or put on a shelf in the hangar until next flying day).
Cheers,
Anders
HUDDINGE Sweden
Jul 23, 2012, 01:51 AM
Grand-Duchy of Luxembourg
Aender69's Avatar
Originally Posted by B34N
Tail servo idea is awesome. It's going to help me heaps with my front end weight issue too.
I'm doing it now. just need a way to connect two control rods to one servo horn :s
B34N
edit: Any chance you can post a pic or two of your tail setup?
Look up post 515...
Jul 23, 2012, 01:08 PM
B34N's Avatar
Originally Posted by Aender69
Look up post 515...
Thanks I am jsut finishing my mod now, I'll post pics when I've finished
B34N
edit: Pics uploaded
Jul 23, 2012, 01:45 PM
Don't Move I've Dropped My Nut
bamaguy's Avatar
B34N
edit: Pics uploaded
That's all well and good, however the weight and mass of the coupler may not be very beneficial...
Jul 23, 2012, 01:53 PM
B34N's Avatar
Yeah, I thought about that, although it seems pretty light. I might grind it down a bit though Originally I wanted to solder the two bits that go to the elevators to the single that hits the servo, but the wire didn't want to play ball with soldering
I can also go the carbon fiber joining method still...
I'll just have to stare at it occasionally over the next few hours before I figure out exactly how I want to do it
B34N
Jul 23, 2012, 02:53 PM
I don't see what the reason is for eliminating rudder function. Saving a few grams is nothing for this plane (if in fact you are saving anything at all). This thing just fits the average 3300 mah battery snugly and balances out perfectly. Removing any weight from the rear and you'll need to add weight to the front to keep the balance. Seems like false economy to me.
If your radio can't do "V-tail", consider getting a better radio. This is probably not the only time you'll encounter it. And then there's landing in a cross wind. You can do it with no rudder, but it's much better with it. "Bank and yank" is OK and has been around for a long time but slow, shallow turns look pretty sloppy. It's like there's an anchor tied to the tail.
Jul 23, 2012, 04:07 PM
B34N's Avatar
Removing weight from the rear means you can also remove weight from the front, not add it.
Also, using leverage principles, the weight of the servo about 50-55cm from the CG translate into over 2x that weight removed from the front.
Correct me if I'm wrong, but that's how I've been looking at it.
B34N
Jul 23, 2012, 04:36 PM
Hmmmmm. I think I would have to gnaw off my left thumb in order to fly a plane without positive yaw control.
Jul 23, 2012, 05:36 PM
B34N
You're right. Don't know what I was thinking. I think what I was trying to say was that with the stock configuration and the recommended battery size, you remove weight from the rear and you "could" put in a lighter, smaller battery. Flight times have always been important to EDF planes. If you could lighten up the battery significantly, you would also reduce fight times. If the weight of a single servo didn't make any significant difference to reduction in battery weight, then why bother? To save weight in favor of ditching rudder control seems odd. Going to "bank and yank" is a backwards progression.
Jul 23, 2012, 07:55 PM
Wretcho's Avatar
Rudder turns with this plane are horrid, not sure why your keen to keep the rudder other then snaps or cleaning up verticals.
I looked extensively in to how to positively mix elevator into rudder as the plane drops it's nose aggressively when rudder is used to obtain some clean rudder turns, with the way the tail works it was an uphill battle.
Jul 23, 2012, 08:19 PM
It ain't just for turns.....
I've used rudder on shallow turns and it smooths it out. Perhaps you're just using too much or you need more expo on the rudder. Why go to the trouble of taking something out that serves a purpose just because you don't use it? But hey, it's your time. It's your plane. Do what you want.
Jul 23, 2012, 08:22 PM
Wretcho's Avatar
Did you even read what you quoted? lol
Jul 23, 2012, 08:38 PM
Yes, I did. Did you read what I quoted? I was stressing the cross wind landing and re-emphasizing the use in turns. "It ain't just for turns", BUT, it still can be used for turns and it's not so bad if the operator isn't so ham fisted at it.
In the final analysis, I could give a ratsass if anyone uses rudder or not on this plane.
Jul 23, 2012, 08:46 PM
bamaguy's Avatar
+1
-Gary
Discussion Battery for the Durafly Dynamic-S from Hobbyking Lars N Foamies (Kits) 22 Oct 10, 2013 01:13 AM
New Product HK Zephyr V70 EDF Glider! SHWEEEET! dustydonnay FPV Talk 33 Jun 29, 2012 11:26 AM
Discussion hobbyking durafly 310 question Syner01 Parkflyers 1 Jun 24, 2012 07:54 AM
Discussion Hobbyking Durafly Telemicro Firehawk989 Micro Ready-to-Fly 5 May 13, 2012 08:09 AM
Help! Replacement prop for HobbyKing Durafly P-51 pabo1 Electric Warbirds 3 Mar 28, 2012 01:07 PM
