This thread is privately moderated by ganapati08, who may elect to delete unwanted replies.
Apr 21, 2012, 08:04 AM
Trader Rating: 0
Unlimited FPV
ganapati08's Avatar
Sold
Xbee Pro 900mhz telemetry kit, good for Arducopter, MK, FPV ) - 100$
Selling two modules and two adapters, bought from udrones used 2-3 times succesfully for my Arducopter telemetry connection (tru APM mission planner), then its somehow XBP09-DPWIT module bricked by signals, dont know how to unbrick but sure its possible look on internet or forums, Dont worry its was PRE-SOLDERED in Udrones so nothing wrong with pins, anyway 900mhz frequency is not allowed in my country so selling theese away for good price. all stuff in perfect condition. You get what you see on pictures.
1x Module Xbee Pro XBP09-DPWIT 156 Rev C (900mhz) (need unbrick)
1x Module Xbee Pro XBP09-DPSIT 156 Rev C (900mhz) (works good 100%)
1x Digi serial interface board (works good 100%)
1x Sparkfun USB interface board (works good 100%)
1x Serial TTL-232R-3V3 cable
1x USB cable
1x Antenna 900MHz RP-SMA 3.1dBi"
Price: 100$ Shipped worlwide.
XBee Pro 900 modules features:
3.3V @ 210mA
Fast 156 Kbps RF data rate
50 mW (+17 dBm) power output
Up to 6 miles (10 km) RF LOS with high gain antennas
Point-to-multipoint networking ideal for low-latency applications
Support for large, dense networks
128-bit AES encryption
ISM 900 MHz operating frequency
Wire antenna / External antenna
Industrial temperature rating (-40 C to +85 C)
Advanced mesh networking and low-power modes supported
Approved for use in the United States and Canada
Self-healing and discovery for network stability
Apr 21, 2012, 08:55 AM
Trader Rating: 1
capt's Avatar
Tried writing firmware 1002 first vs 1061? your pic shows 1061 over @ DIY.
http://code.google.com/p/ardupilot-mega/wiki/Wireless
Apr 21, 2012, 09:46 AM
Trader Rating: 0
Unlimited FPV
ganapati08's Avatar
its still shows..
Getting modem type....OK
Programming modem...Detected baud rate difference.
Make sure PC and modem baud rate is set correctly
Lost communication with modem
Write Parameters...Failed
my baud rate is ok
Apr 21, 2012, 01:21 PM
Trader Rating: 374
I've used this to unbrick.
http://www.instructables.com/id/Chan...a-frozen-Xbee/
Don't worry about step 9.
Apr 21, 2012, 02:54 PM
Trader Rating: 0
Unlimited FPV
ganapati08's Avatar
What u mean about step 9 ?
I dont have reset button... but i heared that i need to short pin 1 and 5... but doesnt help. How to reset exatcly this interface board? Thanks
Apr 21, 2012, 05:43 PM
Trader Rating: 1
capt's Avatar
I think writing the firmware with the xbee removed from the adapter then re-installing the xbee when prompted resets it. I am sure you have tried writing the bricked xbee in both adapters? I had one the needed about 3 attempts to get it to take the firmware, been working good since then.
Apr 21, 2012, 07:04 PM
Trader Rating: 374
Yeah, just like capt said, don't worry about resetting. Just plug it in properly and that will reset it. Then load the firmware again and it should be fine after that. I've had to do it for several different types. Luckily, I'm moving to the 3DR radio set instead so I shouldn't have much issue now.
Apr 24, 2012, 03:20 AM
Trader Rating: 0
bricked xbee
Here is another Instructable that gives a clear demo on how to unbrick an xbee. Let me know if this works. Thanks.
http://www.instructables.com/id/Rest...r-broken-XBee/
Apr 26, 2012, 10:23 AM
Trader Rating: 5
PM sent!
Sold DIYDrones Xbee Pro Telemetry Kit 900mHz kingiggy262 Aircraft - Electric - Multirotor (FS/W) 7 Apr 09, 2012 01:25 PM
Found XBee Pro 900MHz for MikroKopter (plug'n'play) The Big One Aircraft - Electric - Multirotor (FS/W) 1 Feb 19, 2012 11:21 PM
Help! how to configure a pair xbee pro 900 for mk cmulder Multirotor Drone Talk 4 Jan 03, 2012 12:21 PM
For Sale Telemetry modules. for arducopter or others. tc3wins Aircraft - Electric - Multirotor (FS/W) 0 Nov 13, 2011 09:21 AM
