Feb 23, 2020, 09:12 PM
Registered Hoser
Cptn. Krunch's Avatar
Hahaha, it won't even hold a 5000 down. I added a block of foam to the canopy cover to hold a.4000 in place. I removed the strap.
Feb 23, 2020, 09:17 PM
eat, sleep, FLY FLY FLY
Mr.frankenjet's Avatar
yup battery goes way forward of the strap
Feb 24, 2020, 02:33 PM
nsr500v
Fms misinformation with C/G
I have several FMS ww2 planes and the Strap position almost always seems to be in the wrong spot aft , if you are gullible enough to not go with the standard 25 to 30% rule for most WW2 planes This will get the new warbird pilots for sure
Feb 24, 2020, 04:13 PM
So is the cg in the manual still good?
Feb 24, 2020, 04:35 PM
Registered Hoser
I am going to fly it with the CoG at 72 mm back. I don't remember what the manual says. I listen to the fellas here. REAL experience from real flyers.
Feb 25, 2020, 10:03 PM
I'm a foam wedge / foam block guy as well...although with my current 109 I only sanded the battery compartment just far enough to make for a tight fit so that nothing else is required...no disasters so far lol
Feb 27, 2020, 10:00 AM
Registered Hoser
I too cut some foam out just for the fit of a 4000 4 cell Hyperion. I like a little wiggle room in the battery bay for some air movement. Looks like I finally get to maiden this weekend. Its a bit early in the year but the tarmac is slowly melting .
I have pulled this off the rack a dozen times just to admire the thing. One day I have to get into the cockpit and fix that up. Other than that, she's ready to fly.
Feb 27, 2020, 10:27 AM
rc informer has a good review, I put my battery up on it's side as well , good luck, SLOWW with throttle on takeoff )
Feb 27, 2020, 10:39 AM
Registered Hoser
Thanks Mr Frank. I have 1500 ft so the take off will be cautiously gradual. At least until I get the feel of the plane. The FMS 109 will be less challenging than the Dynam 109. More forward rake and less wing loading. Expo is set at 58% for rudder as well.
Feb 27, 2020, 11:10 AM
good luck, give plenty of rt rudder rolling out as well Shes a great flyer
Feb 29, 2020, 01:55 PM
Creative RC's Avatar
Assembled after a long wait. Lots of kudos for the folks at FMS. A very simple build! Minor weathering and a little vinyl on the wing tips for the inevitable dance on landing Other than adding the pitch mod I will fly it stock. If I need an extra boost I may pop in a Surpass 4260 600kv. That motor really woke up my Corsair! I run 4 cells on all the other FMS and for my purpose, they do the job.
Cheers!
What does the pitch mod consist of. I must have missed reading that one. Thanks.
Feb 29, 2020, 02:15 PM
Registered Hoser
I installed some carbon strips behind my prop on the mount plate to increase the pitch of the blades. I'll start with the 1mm and measure the real unload amps to determine if I need more. The stock motor can handle the added amp load as the P51 has it as well. Speed is fantastic.
Feb 29, 2020, 09:24 PM
Oh, sorry, I did read about that before but have not yet applied it. When I asked, I thought maybe it was a change in the horizontal stabilizer pitch (or decalage), whew, glad it is not. Thanks for your reply.
Mar 01, 2020, 01:40 AM
Registered Hoser
Not a problem. There is some great advice on this and the FMS P 51 thread too. All kinds of tips to give you more fun.
Cheers
Mar 01, 2020, 03:23 PM
Registered Hoser
Yet another mothball day for weather. Oh well, I made some pilots. Now, which one looks the most German. No, not the zombie one. He's going in my B25 (Heavy Metal)
Discussion FMS 1400mm FW-190 Owners Thread Orion Pax Electric Warbirds 9668 Mar 19, 2020 06:43 AM
Discussion fms warbird owners thread warbird_cowboy Electric Warbirds 126 Mar 11, 2015 08:13 PM
New Product GAUI 500x/ GU-INS GPS Owners Thread - Tips, Problems And Experiences sap_2000 Multirotor Drone Talk 231 Aug 05, 2014 04:32 AM
New Product FMS Messerschmitt Bf109F 1400mm Beltpilot Electric Warbirds 1299 Mar 30, 2013 09:24 AM
Poll Choose the paintscheme of the new FMS GIANT Bf109F Beltpilot Electric Warbirds 41 May 31, 2010 05:44 AM
