Apr 19, 2012, 10:06 AM
What's 3D?
trumps's Avatar
NEW FMS Bf109f owners thread.
Ok, seeing as nobody else has started one i suppose i might as well get the ball rolling with a bit of an assembly and flight test thread on the new 109, i figure that being as the new 190 owners thread format seems to be working out quite nicely with lots of good info, and troll free comment we should do the same here, though i wont be offering a step by step build vid, (i'm ok behind a video camera, but you really don't want me in front of one )
my plane turned up damage free, and in only 4 business days from PW-RC, i also picked up a couple of 3300 nano-techs, and an AR-7010 reciever for it. upon opening and inspection i found the elevator hinges were cracked up in a couple of places, i slotted these and slipped a couple of CA hinges in to them. 1 of the 4 wing mounting bolts was missing as well, i will rat through my stocks of bits and should be able to come up with something, no biggie.
after reading about some of the issues that are being had with the motor i removed it and opened her up to check the magnets, and stator for security, all looked fine but i ran some thin CA around the magnets as a bit of insurance, and made sure the collar was well tightend, and the grub screw located on the flat of the motor shaft. glued the wings and tailplane together with the supplied glue after giving the mating surfaces a bit of a roughup with some sandpaper, i'm not really jazzed about the way the wing halfs mate up, with only about 50% contact area, i will fill the gap with epoxy tomorrow.
there is a fair old birdsnest of wiring wich will need sorting out, but i plugged everything together, and checked that all functioned, all good, though the ESC wouldnt arm up until i calibrated the throttle.
well thats about it so far, hopefully will get her buttoned up, and maidened over the weekend weather permitting and if all is well after that it will be time for a fresh coat of jam, and a spruce up!
Cheers
Craig
Apr 19, 2012, 10:36 AM
What's 3D?
trumps's Avatar
some more pics, for some reason it wouldn't let me upload them all in the 1st post.
Apr 19, 2012, 11:14 AM
Prowler901's Avatar
Nice pictures Trumps. Thanks for posting them. It really is a great improvement over the previous 109.
Todd
Apr 19, 2012, 01:48 PM
TripleW's Avatar
Trumps, Are the insignias decals or water slides?
Apr 19, 2012, 04:13 PM
demire's Avatar
I plan on getting one of these down the road and re-painting it. The lines look great on this and deserves a meaner paint scheme. Look forward to all the information on this one!
Apr 19, 2012, 06:19 PM
bouncebk2003's Avatar
As nice as this models is,that enlarged vertical fin just really bugs me.I have a Parkzone 109 and it flies great.Granted the enlarged fin would improve directional control,but it's a warbird man!Not a cub.I dislike it when a designer will tweak an airframe to make it easier for the masses to fly.Sorry if that sounds critical,but I prefer a challenging aircraft.If a trainer is needed,then go get a trainer! Nuff said.
Apr 19, 2012, 07:20 PM
Most people are stupid!
dambit's Avatar
FMS never use water slides. They are decals. Easily reapplied with some spray adhesive.
@ bouncekb2003 - Dude it's called an Stanley knife and it has the ability to cut foam.
Cheers,
Steve
Apr 19, 2012, 07:40 PM
demire's Avatar
What's the best was to remove the decals cleanly other then very carefully?
Apr 19, 2012, 07:58 PM
What's 3D?
trumps's Avatar
mate it is a foam ARF and i have never seen one yet that is perfect, if i wanted a master scale model perfect in every way i would build one but i have far to many builds on the board already! the parkzone 109 might have a closer to scale v-stab but even they have made compromises, just look at the undercarrage, or lack of it in most cases! as dambit has posted above, if it offends your sensibilities to such a huge degree buy one and fix it your self, if not move along!
Craig
Apr 19, 2012, 09:43 PM
dambit's Avatar
Not sure, in the past I've just pulled them off. The aren't too fragile so they come off in one piece. Hopefully
Apr 19, 2012, 11:40 PM
Craig
Yes I agree Parkzone made compromises and yes,mine is a belly flopper so no landing gear whatsoever.Don't get me wrong,the FMS 109 has lot's to like,including the retracts and nice scale flaps.It's just such a shame that they got so much great detail,and then screwed up the tail!Yes,I do know how to fix the tail,and I probably would if I were to buy one.And I just might.
Apr 20, 2012, 01:10 AM
What's 3D?
trumps's Avatar
pretty much ready to go, just need to get some selfadhesive velcro to secure the battery. don't know if the sticker is facing the wrong way, and velcro strap for the pack is of no use because my 3300 pack needs to go quite a way forward of them to achieve CoG. will soon see though i guess all in all a nice looking model!
Craig
Apr 20, 2012, 11:28 PM
Angry Bird ...
yarrumevets's Avatar
Good luck with the maiden Trumps! Will be very interested to read a report.
Steve (... yes, there are a lot of us)
Apr 20, 2012, 11:37 PM
What's 3D?
trumps's Avatar
done deal, maidened the 109 today and it flys magnificently.
the recommend CoG is spot on, it tookoff very nicely in a very scale manner at barely 2/3 throttle, and climbed out nicely. i flew a couple of circuits with gear down just to get a feel for her, but when i went to retract the gear it would not raise all the way, i cycled it a couple of times but no joy, in the end i rolled it on it's back and they retracted properly. it has plenty of power, cruising nicely at half throttle, and no trim adjustment was required at all. she flys a nice large loop, and is pretty axial in the roll. with some height i lowered the gear, and the flaps and she slows down very nicely, with only a slight nose down change in pitch. my timer was set for 5 minutes, and when it went off i brought her in to land, maintaining about 1/4 throttle she sunk, and settled on the mains though floated off a bit into a slightly quatering headwind, due to the narrow track and wind she rocked about on the mains a bit and slightly scuffed the trailing edge of the outer wing tips (some glass tape in this area would be the go) she showed no sign of nosing over , even as i taxied of the bitumen strip onto the grass.
unfortunately i lost the air intake on the maiden, i had only tacked it in due to wanting to be able to remove it when i repaint the model, i have contacted Philip at PW-RC to see if he can order one up for me, plus another decal set.
the second flight was even better than the first!i raised the gear as soon at she lifted off, and it went all the way up, i should imagine due to the lower airspeed not causing them to trip out, looks nicer this way anyhow . i would recommend a spot of loctite on the spinner retaining screw as it came loose on both flights.
after 5 minutes of mixed flying , but mainly at 1/2 -2/3 throttle my 3300 nano-techs took approx 1600mah to recharge.
all in all she is a cracker, and is very solid in the air, Me likey
hope i can get some more vid tomorrow.
FMS 109f maiden (4 min 4 sec)
Cheers
Craig
Apr 20, 2012, 11:48 PM
TripleW's Avatar
Congrats!
I have had good luck reusing FMS decals. Just use some spray adhesive to reinstall.
Discussion FMS 1400mm FW-190 Owners Thread Orion Pax Electric Warbirds 9668 Mar 19, 2020 06:43 AM
Discussion fms warbird owners thread warbird_cowboy Electric Warbirds 126 Mar 11, 2015 08:13 PM
New Product GAUI 500x/ GU-INS GPS Owners Thread - Tips, Problems And Experiences sap_2000 Multirotor Drone Talk 231 Aug 05, 2014 04:32 AM
New Product FMS Messerschmitt Bf109F 1400mm Beltpilot Electric Warbirds 1299 Mar 30, 2013 09:24 AM
Poll Choose the paintscheme of the new FMS GIANT Bf109F Beltpilot Electric Warbirds 41 May 31, 2010 05:44 AM
