I fly close, and there isn't much difference doing that inside, except you reduce the risk of a blade flying off and hitting your neighbor in the head.
The risk of a helicopter exploding is minimal, but it's the same flying inside or outside. |
Never thought of it this way, but you really got a point there (just that the effect of something going wrong will be WAY more severe ... depending on the heli of course ...)
Latest blog entry: Random Pictures ...
"hey y'all, hold my beer and watch THIS!"
Nice! I've heard that joke before, and still laugh at it.
I fly close too if I am just hovering around, but my skill level would not allow me to even hover indoors. I once had my 450 running wood blades nick a wood fence, and those blades literally exploded All I had left were tooth picks. Just too easy for something to wrong. Now, back to the 130x. Yes, actually is a robust bird to fly and crash once in a while. My batteries are about a year old, so getting less snappy, but still fun. |
I doubt that statement. I think if a Blade by itself went flying off, then its motion would probably quickly flutter into nothing like a feather. I say this because I don't think a flying Blade will shoot out like an arrow with its tip traveling directly away from the Main Shaft, but instead will "shoot" out "on-edge" traveling "forward" towards its entire leading edge, and therefore would experience relatively MUCH air-resistance and turbulence, which would make if fly more like a loose feather than an arrow. I've had 100 size heli flybar weights fly off inside my living room, and those are definitely flying projectiles (they sound like BB's when they hit the wall), and I definitely wouldn't want to be hit in the eye with one. But if it were a Blade, I doubt it would even make it to the wall (although I've never had a Blade fly off, so it's just my SWAG (Scientific Wild Arse Guess). |
Reason: clarity
Each will assess their risk and act accordingly.
This is what I would call a low probability high impact (no pun intended) event. Assuming you take reasonable care of your aircraft and keep it in good shape and inspect it prior to flight the chances of a blade grip coming loose are very small. Almost negligible. If a blade comes off and strikes your big screen TV or wife/child the consequences are high. This is what causes most to avoid the risk. Truthfully you are at more risk every day the moment you get in your car and leave your home. No I didn't check any statistics but I'd bet that I'm right. The good news is the Blade 130X rotor blade is unlikely to cause any permanent damage unless it strikes an eye or something. Still, I've never flown inside my house. I keep it to the back yard. I'm not inclined to discuss the flight characteristics of a helicopter rotor blade separated from the helicopter. |
I agree the likelihood of a blade coming is extremely low (without contact with something especially). Then you factor in the odds of hitting something important. Then factor in the odds of that something important being hit in a critical spot...
If I ever get the balls to fly something as large or larger than the 130X, I'll make sure those balls are protected |
I do the same, and use yellow to enhance visibility
It's not like I do it all the time, but I used to live in an apartment and I didn't have much choice. I figured it would have damaged more valuable property to have an accident in the parking lot. Now I just go out in the yard. I would hover up to a 700 in the yard, but for flying around I wouldn't go over 250 size without a proper flying field. The 300 is a little cramped in the yard, and that's about the size where it could break a car window or seriously injure a pedestrian or something. Kids ride their bikes on my street and I don't always see them coming when I'm standing in the yard. It's all about weighing the risks and making a smart choice. Flying 450s in the house a lot probably isn't good, but hovering it while you're testing once in a while is no problem if you're smart about it. I've flown my 550 hex in here too, just not on auto-pilot
Except for a few Flybar weights flying off (which were totally my fault for not having them secured enough), I've never had anything else break during flight; however, I've seen a few videos people posted of larger helis where something broke (a link pop off, etc.) in flight, which caused them to totally loose control of their heli, resulting with the heli ultimately crashing where it wanted.
I suppose the crashes from popped off links, were probably all due to pilot error also. Outside, up high in the air, there's probably enough reaction time/distance to toggle the Throttle Hold switch before Blade impact, but inside a small living room the only way I'd feel safe hovering a large heli is if I was hiding behind something sturdy, like the guy hiding behind the bar stool in the above Raptor video. |
Thread Tools | |
Similar Threads | |||||
For Sale | New in the box E-Flite Taylorcraft ARF Kit plus High Performance E-Flite components | Philscho | Aircraft - Electric - Airplanes (FS/W) | 4 | Aug 19, 2012 12:25 AM |
For Sale | E-Flite 300 32e SHP ****SOLD*** E-Flite still aviable | tomtheman | Aircraft - Electric - Airplanes (FS/W) | 2 | Mar 28, 2012 08:01 PM |
Sold | E-flite 60A ESC w/ E-flite Brushless 1010kV Motor | joshfneptune | Aircraft - Electric - Power Systems (FS/W) | 3 | Mar 05, 2012 09:18 PM |
Discussion | E-Flite Taylorcraft 450 ARF Kit and High Power E-Flite electrical components $300 | Philscho | Hot Online Deals | 1 | Mar 02, 2012 09:11 PM |
Discussion | E-Flite Su-26 and E-flite Extra 260 repair | Joe Slow | Crash Discussion | 1 | Sep 27, 2011 11:50 AM |
