Turnigy 9XR - Page 360 - RC Groups
Feb 11, 2013, 10:20 PM
Warbird Fanatic
jchtr3a's Avatar
QUOTE}
This issue doesn't arise with a Spektrum programmable transmitter because the type of receiver associated with each model memory is stored when the receiver is bound. But this can't be done with a module (which is why the Spektrum module works only in DSM2 mode).[/QUOTE]
Thanks, now I see why it began working. It's nice to have folks who know their way around this stuff, and are willing to share their expertise with those of us who are "technically challenged".
Thanks again.
Feb 11, 2013, 11:47 PM
Tassie Electric, Heli, Glider
ChrisJ800's Avatar
Originally Posted by nogas
Only problem i found so far was the double sided tape holding the screen on had let go so the screen was floating around in the bag. It wasn't damaged so it was just a case of sticking it back in place and applying some firm pressure so the DS tape would grab.
Isnt that removable screen protector film for transport only? If mine had it, I threw it away, cant remember now!
Feb 11, 2013, 11:49 PM
hjukhjuk
gooby's Avatar
ChrisJ800, I think he's talking about the plastic plate that goes in front of the lcd.
Feb 12, 2013, 12:23 AM
Its actually real glass on the 9XR !!
Feb 12, 2013, 01:05 AM
Because gas is for BBQ's
nogas's Avatar
seriously??? I know you guys are disconnected from the main land but i didn't know you were that slow on the up take
and yes, as KKUSA said, its real glass.
Feb 12, 2013, 01:54 AM
Mark Harrison
Is it really? I got so lucky... when my exit button was sticking I just stuck my pocket knife blade between the cover and the button, and wiggled it around until the gap was opened up a bit.
I thought it was plastic, so I was quite cavalier about doing so... Guess I got lucky!
Feb 12, 2013, 02:04 AM
I think its a borosilicate glass, so its a bit tougher than normal glass and doesnt chip as easy.
Feb 12, 2013, 07:24 AM
hjukhjuk
gooby's Avatar
I'm amazed it has a glass screen cover, you would think Hobbyking would have gone for the cheapest option.
I guess someone has to be the first. I had my 9XR for about an hour and ruined the throtle pot. I forgot I am a cave man. You DO NOT put a flat blade screw driver between the body of the pot and plastic gimbal. It is totaled out. I've looked through a few hundred threads about pots on the 9X. A picture was posted of one on a Chinese web site. Not sure how to contact them. Of course I contacted HK, they haven't gottten back to me yet. Hoping they just pull one from their assembly line. I may be saved by a 4 year old FLYSKY CT6A radio I have. The gimbal pots are much too large. However the 2 Pots on the top of the radio are almost exact size. They are panel mount, so the bearing is threaded and the shaft is round and split for a nob mount.So i'm moding it. Physically its going to fit! I don't want to alter the gimbal in case I get an actual replacement.
Feb 12, 2013, 07:26 AM
hjukhjuk
gooby's Avatar
KCLC, why on earth would you do that?!
I'm sure someone here knows where to get a replacement.
Feb 12, 2013, 07:43 AM
Registered Addict
Stigern's Avatar
I finally found use for the protective pad that comes with the 9XR hehe. Got my 9XR battery pack yesterday!
Fits nicely! Loving it.
Btw, what is a safe value for voltage alarm? 9,5volts?
Where do you guys position your Frsky telemetry monitor?
Feb 12, 2013, 07:45 AM
FPV Crash Dummy
igorp's Avatar
I remember Anthony Hand posting early on saying that the screen is going to have gorilla glass.
Feb 12, 2013, 10:21 AM
Embargo lifted.
kenstogie's Avatar
woo hoo! My 9xr is waiting to be picked up at the PO.
Feb 12, 2013, 10:29 AM
Ok. After 24 hrs. I have my new 9XR changed from MODE 1 to Mode 2. That pot from the old CT6A works good. I did a recalibrate on the sticks. and all is good. If you want to appreciate the quality of the 9XR, take a look at the insides of what we were buying 4 years ago.
Feb 12, 2013, 01:43 PM
Bad command or file name
Imageek2's Avatar
I set my voltage alarm at 11.1 just like my quad. I mounted the telemetry module in the same spot.
Discussion Gens Ace, Turnigy, Turnigy Nano-Tech Sky lipo, etc. What's Your Preference? jlloyd1995 Batteries and Chargers 133 May 14, 2015 11:53 PM
Sold 2 turnigy motors 2 turnigy esc's crashnburn69 Aircraft - Electric - Power Systems (FS/W) 4 Oct 13, 2012 12:05 PM
For Sale Turnigy 2x 3s 1000 mah and 2s 1000 mah and Turnigy 2s/3s Lipo charger. Falconpunch Aircraft - Electric - Batteries & Chargers (FS/W) 1 Mar 18, 2012 10:47 PM
Discussion Turnigy or Turnigy Nanotech lawguy14 Batteries and Chargers 4 Mar 15, 2012 09:48 AM
