Apr 03, 2012, 04:26 PM
GP Micro Sabre Radio Problem
Hi all
I have a DX6i radio I want to use with this any link system for the Micro F86 Sabre.
I connected it to my radio,powered the plane and now the plane sits there buzzing,like the servos are oscillating. Only the elevator will work,in reverse of course,the throttle won't work neither will the rudder. So I changed the channel mapping on the radio,the ailerons now work but with the throttle control,the elevator works but when i activate the control,the ailerons also move.
Is there something I am completely missing with this radio setup? I still have no throttle control no matter what map set I use.
Apr 03, 2012, 05:22 PM
Ok well an update. I got the throttle to work, but am still having the problem where if i apply up or down elevator,one aileron will move as well. Any ideas?
Apr 03, 2012, 07:43 PM
Both ailerons should be moving together, as they are mechanically linked to the same servo.
Have you checked to ensure that all your mixing programs are off, like delta/V-tail mixing?
Apr 03, 2012, 08:53 PM
I know they should move together,but they shouldn't move with the elevator. I am going to play around with it some more.
Apr 03, 2012, 09:05 PM
I finally figured it out.It was in elevon mode.No idea how it got there,no plane has ever defaulted to it before,but this one did.Works like a champ now.
Is it normal for the servos to constantly 'glitch' as great planes calls it-buzzing,etc? I tried moving the trims but it still does it.
Apr 04, 2012, 12:21 AM
Team30 Micro EDF
NitroCharged's Avatar
Time to update the thread title to "GP Micro Sabre Radio Problem - SOLVED!"
Which servo is humming?
Apr 05, 2012, 03:05 PM
Effumall
kelberts's Avatar
Servos usually make noise because they are pushing against something keeping them from being in neutral, or because they are defective.
Apr 05, 2012, 05:58 PM
Since it's pretty much a RTF plane:
If your control surfaces are centered and the servos are buzzing, then it's normal for servos to do this because they are constantly trying to center "just right."
If the control surfaces aren't centered and they are buzzing, something may be wrong. Look for any binding/friction. If they are buzzing and the servo seems to be stuck at some position out of center, there could be someting hanging up on the control mechanics or if not, a stripped servo internal gear.
Typically what I, and I'm sure most others would call a servo glitch:
- The servo sporadically spasms position, which can be seen by the control surface twitching out of position without any commanded input from the transmitter.
- The servo rapidly jumping through a certain positional range which is inconsistant with your transmitter input. For example slowly deflecting the rudder via the transmitter, but the rudder suddenly lags/jumps through some positions.
Discussion GP micro F-86 Sabre chat thread livonia bob Micro EDF Jets and Power Systems 537 Mar 06, 2013 01:38 PM
Build Log GP Sabre Symetrical Wing Build Thread Kevin Greene Micro EDF Jets and Power Systems 10 Mar 02, 2012 06:08 PM
Sold F86 Sabre 35mm EDF Micro Jet EPO (PNF) strangerb43 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 Feb 26, 2012 04:43 PM
Off Site Great Planes 30mm Brushless Micro EDF F-86 Sabre battery adapters glenn2626 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Feb 26, 2012 02:17 PM
Help! GP C-12 Micro with GP Electrifly T-400 - Problem fixed - post can be deleted BennettOZ84 Electric Power Systems 1 Jul 13, 2007 02:34 AM
