This thread is privately moderated by joyanan, who may elect to delete unwanted replies.
Mar 28, 2012, 03:03 AM
Gas Model Airplane Buy Tips (RTF, ARF, Kit)
Gas Model Airplane Shopping Tips (RTF, ARF, Kit)
Gas Radio Controlled Planes are more complicated, and which can be found in many different variations all suiting different levels of skill and passion. So it is probably a good idea that only more experienced fliers fly gas planes.
gas model airplane
Gas planes usually have more expensive maintenance costs, as well as greater start up costs as opposed to electric planes. Gas planes are also difficult to learn how to fly, so When choosing the right gas plane, you will need to decide if you are going to need an instructor or if are you going to learn by yourself. If you are a beginner you should get a trainer gas rc plane, as this type of plane will help you to learn good flying skills. There are a number of options which you should look at when buying a gas radio controlled plane:
*You should choose a trainer gas plane if you are a beginner
*Wings should be high up on the fuselage above the cabin area
* wing should be large because more lift is created and will make the airplane fly slower
*Look for tricycle landing gear to make landings easier
*A flat bottom wing air foil section for better lift
*Buy a 4 to 6 channel transmitter now
*The bigger the plane, the easier it is to fly
Ready to Fly Gas RC Planes(RTF)
Picking out the right gas rc plane is very important as you don't want to waste your time and money on bad ones. Not too many years ago remote control airplanes required hours and hours of building but now it also comes in a popular ready-to-fly kit (RTF). Some would argue that it takes all the fun away not building it yourself. This is though a matter of opinion whether you like the flying or the construction itself. Especially for the beginning remote control airplane hobbyist there are several advantages to the ready-to-fly planes.
Ready-to-fly pros and cons
Firstly, the remote control airplanes tend to be cheaper so it's not the end of the world if you go crash it. Secondly, many of the models come in aerodynamically stable models that are not too advanced to control for a beginner. Although this means that you might get bored later it still it's good idea (and cheaper!) to start easy. And thirdly, they are of course easy to go fly right away for those of you that tend to be impatient ;0)
Almost Ready to Fly Gas RC Planes(ARF)
Many Model RC airplanes come as almost ready-to-fly kits. And An experienced flyer may kind an almost ready to fly gas plane is perfect. Gas planes fly longer, go higher, and are more stable.The difference from the ready-to-fly kit is quite obvious: It takes a bit more work from you, but not very much. You'd typically spend somewhere between 10 to 30 hours building it.
Let's have a look at a few Almost Ready to Fly models:
Sbach 342 50cc ARF
Sbach 342 50cc ARF
Wing span: 2260.6mm/88"
Length: 2110mm/ 83in
Wing area: 76sq.dm
Engine: 50-60cc
Empty weight: 3550-3800g
Radio: 6-9 channels
Flying weight:7000-7400g
Carbon Fiber Roll Tube: 25*23*835mm
Optional choice: FP2029
Carbon Fiber Roll Tube: 12*10*345mm
Optional choice: FP2012
Gas RC Planes Kits
Building a gas plane from a kit is no easy task. If you decide to buy a kit then you should be prepared to spend a little extra money as well. One word of advice when buying a kit for a gas plane is that you should always get a giant. Giants are the best to build from a kit because they produce a more satisfying plane and they tend to last longer.
What You Will Need:
A gas rc airplane (RTF, ARF, Kit)
A 2-stroke or 4-stroke engine
A fuel pump
A starter for the engine
A battery to ignition the glow plug of the engine
A 4-6 Channel radio control transmitter
The Batteries for the radio control system
gas airplane accessories
Tips:Not matter you wanna Gas Model Airplane RTF,Gas Model Airplane ARF,Gas Model Airplane Kit or gas airplane accessories,You will know what you need to buy through the Best hobby store and what you don't need to buy also be told.
China wholesale discount gas airplane
For Sale New Pitts 50CC ARF RC Model Gasoline Airplane joyanan Aircraft - Fuel - Airplanes (FS/W) 0 Mar 26, 2012 03:03 AM
Sold MK Laser 200 F3A RC Model Airplane Kit lanilll Aircraft - Fuel - Airplanes (FS/W) 0 Mar 08, 2012 08:52 PM
For Sale R/C Gas Model Airplane Engines - $350 LPU BobWells Aircraft - Fuel - Engines and Accessories (FS/W) 1 Jan 18, 2012 08:46 PM
New Product NEW! MONSTER THRUST VECTOR EDF F22 buy the RTF get ARF kit free? rjp0325 Electric Ducted Fan Jet Talk 17 Sep 24, 2010 07:12 PM
