Mar 27, 2012, 02:52 PM
Need help setting up stryker with dx6i.
I'm having a problem setting up the um stryker. After binding it everything worked except one elevon. After reading closer the instructions specify if using a dx6i you must reverse the leads on the transmitter and it shows you a little diagram showing which two need to be reversed. No big deal. After doing it now both elevons work, but only as ailerons with no elevator function at all. I am a newbie at this and wont be flying the styker for a few months but I still want to set it up.On the transmitter I set the function to delta wing and still no change. Anyone have any ideas ? Thank you.
Mar 27, 2012, 10:51 PM
Do you have the wing type set to elevons?
Mar 28, 2012, 03:35 AM
I got it fixed, thank you.
Discussion Need help setting up ER9-X with Naza tgreening Multirotor Drone Talk 34 May 15, 2012 10:58 AM
Discussion Need help setting up stryker with dx6i. John S. Beginner Training Area (Aircraft-Electric) 6 Mar 27, 2012 07:12 PM
Discussion Need help setting a LP5dsm up to buddy box W/dx6i pops57 DIY Electronics 1 Mar 16, 2012 04:33 PM
Discussion Help with how to set up the DX6I for s-cub and champ etc. video fishycomics Radios 0 Jan 13, 2012 04:49 PM
Discussion Need some help setting up Elevon in Dx6i FoamieFlier Foamy EDFs 3 Jan 06, 2012 08:59 AM
