This thread is privately moderated by xandrios, who may elect to delete unwanted replies.
Mar 26, 2012, 08:12 AM
Steven
xandrios's Avatar
Data
Delta DPS-1001AB-1 48V 700w/1000w, Delta DPS-1500AB A Full Pinout
Delta DPS-1001AB-1 48V 700w/1000w, Delta DPS-1500AB A 48V 1500w full pinout.
Connect PS on and PS Kill to ground to power up.
Feb 04, 2013, 09:18 PM
Revolectrix Ambassador
FANC to ground to slow fan speed? Or do think 2v-3v is required?
Jul 23, 2013, 07:15 AM
Dear Xandrios
I'm sorry for bothering you
I'm interesting to make current sharing by connecting two power supplies Delta DPS-1500AB A
Would you be so kind , and explain please , is it possible to do so , if yes , how can I connect them together , to get 48vdc 60amp .
Thanks a lot .
Jul 24, 2013, 12:17 AM
I'm doing this now with two DPS-1001AB-1 supplies. Connect the 48LS (load share), pins on both supplies, pin D3.
Jul 30, 2013, 11:49 AM
Thank you Gregor99 for your helpful reply.
Mar 03, 2014, 06:18 AM
hi xandrio's i am really sorry that i have to badder you but i have both two Delta DPS-1500AB A to Pinout them out but i am not able to pinout any of them is there something i am doing wrong i did bind the three pin that you show on the site but it does not work is there something else to it could please let me know i am
Jun 27, 2014, 01:19 AM
I have two DPS 1200AB. Same as the 1500W or 1000W units. All I did was to connect the DC 48 V outputs in parallel ie P1-P1 and P2-P2. Both units can touch their cases. Then is needed in order to power on the units and to slow down the fans to connect B2-B3-B4-A6 of the each unit together ie. unit1(B2-B3-B4-A6 )-unit2(B2-B3-B4-A6 ). To share the loads the D3 pins needs to be connected together (as mentioned above by the other users) ie D3-D3. For all my connections I used servo connectors which perfectly fit the pins.
Now you have two units which can operate individually and also in parallel. You can now connect the AC plug in both or just in one unit.
Here you can see my Duo 4010 in full load [email protected] per channel charging 2x12s.
Duo 4010 & 2×DPS 1200AB (0 min 46 sec)
Jun 27, 2014, 10:17 AM
FANC to 12VSB RTN to slow the fan speed.
Jun 26, 2015, 02:14 PM
quite an old thread, but: any ideas how to adjust voltage and current output?
Jan 08, 2020, 08:38 AM
Hi everybody,
Sorry to reply to so old topic but I cannot find a solution.
I want to power my icharger 4010 duo by 2000W.
I bought a server Delta power supply DPS-2000AB, I thought the pinout will be like DPS-1200AB, but I was wrong.
Can someone help me to find the correct pins to short?
Thank you
Discussion Looking for someone to build my twin F-22 Raptor chicago IL sherlockshah Electric Ducted Fan Jet Talk 3 Feb 27, 2012 07:43 AM
Discussion Looking for someplace/someone that can cnc fiberglass. ukarmy04 The Builders Workshop 6 Jan 01, 2012 02:27 AM
Off Site NOT MINE! but it's a deal for someone, just passing it on. bhbs Aircraft - Fuel - Airplanes (FS/W) 0 Dec 27, 2011 09:05 PM
Discussion Looking for someone from FPV Hobby Canada Goose Aerial Photography 2 Oct 27, 2011 03:22 PM
Discussion I need the strongmanrc.Link redirects..can someon post it for me Boss248 Power Systems 1 Jan 15, 2008 08:33 AM
