Jul 19, 2014, 06:36 AM
Another beauty night of flying.
Tuff Wing FPV Fun (5 min 14 sec)
Dec 21, 2014, 10:39 PM
San Mateo, CA
HPCR's Avatar
32 inch TUFF Wing completed
Folks, I just bough a TUFF WING and built it in one day. Here are some pictures. Now just waiting for the weather. Great build, had a Turnigy L2210-1650KV and HXT900 servos ( did not even need servo extensions) laying around and I just shortened the shaft to install the prop. Here are some pictures.
Dec 21, 2014, 10:42 PM
San Mateo, CA
HPCR's Avatar
Curiosity kills the cat
Could be ....
Dec 22, 2014, 06:40 AM
Volunteer's Avatar
You'll have a blast. It's one of the best flying planes I've owned and right out of the box(bag). Try to figure out if I want to go to 4s and probably ruin it.
Dec 22, 2014, 11:23 AM
kgd1's Avatar
Nice! Its a awesome wing, you'll love it. I will be ordering another 32 for a 6s set up.
Dec 22, 2014, 12:28 PM
San Mateo, CA
HPCR's Avatar
So Far So Good but what about the CofG?
I liked the build and the ingenious way for the mfg to cut the foam with an "airfoil" contour and put it all together again to ship in a very small ( safe-to-ship) plastic bag.
I am just hoping the motor I installed will have sufficient power to provide a nice speed and crisp handling , it is 250 Watts so it should be fine with the 7x4 prop. In a rev-up test is gave a serious amount of thrust. I think it will do vertical flight with 1/2 throttle for sure but the maiden will tell me.
One question for you guys in COG, what would be a good number to start off with?? I hear 4 1/2 to 5 inches from the nose??Is that about right??
Dec 22, 2014, 12:51 PM
kgd1's Avatar
With a 3s2200mah battery, There is really no room for adjustment. Just put it in the pocket and go. You just have to adjust your elevons mechanically or TX trim.
Dec 22, 2014, 07:01 PM
Volunteer's Avatar
Which motor and what size 6s?
Dec 23, 2014, 12:59 AM
kgd1's Avatar
Motor-
MT2836 Series 1200KV High-Powered Brushless Motor
Battery-
Glacier 30C 1200mAh 22.2V 6 Cell LiPo
Dec 23, 2014, 11:47 AM
Volunteer's Avatar
That combo ought to get you there!
I noticed my 32 porpoising at high speed so I slipped some carbon tubes over the aileron push rods and that stopped it. With your 6s setup you will probably need some kind of reinforcement too.
Dec 23, 2014, 12:56 PM
San Mateo, CA
HPCR's Avatar
That is one hell of a motor! It's going to twist the wing :-)
Dec 24, 2014, 02:41 AM
how easy it is to setup cg on this wing? how tough is it? I want to use it for fpv mainly with mobius and fpv camera....I can fly quadcopters and 3d foamy planes... Can this be my first flying wing? how stable is this?
Dec 24, 2014, 03:44 AM
this is a great wing as long as you don't modify it. I tried some changes and just messed it up, seems great as is (only). There are a few where we fly, stock build with the NTM 2836-3000 is superb, insane speed. Round peg for square hole if you weigh it down, etc. Not a beginners wing, way too fast (if there is such a thing)
Dec 24, 2014, 07:37 AM
Volunteer's Avatar
I don't understand why there isn't more talk about these wings. They're priced right and fly great. The only trouble I've had was from a broken motor mount just like in the EFX thread. I replaced it with a C/F X mount and all is good so far.
I sure would like to see a 36"-40" version of the Tuff Wing.
Dec 24, 2014, 11:18 AM
kgd1's Avatar
I agree. It has a covered electronics bay, It does 100mph out the box (with recommended set up), Flies like it's on rails, repairs easy, electronics are top mounted. Its a awesome wing.
Sold 24" tuffwing tonkajeep34 Aircraft - Electric - Airplanes (FS/W) 3 Feb 09, 2012 11:17 AM
Wanted Wings Swift or superfly speedwing tuffwing Fl410 Aircraft - Electric - Airplanes (FS/W) 0 Nov 24, 2011 01:48 AM
Wanted superfly, MS Composit Swift, Popwing, tuffwing Fl410 Aircraft - Electric - Airplanes (FS/W) 0 Nov 20, 2011 11:20 PM
Wanted Wing Popwing or Swift or speedwing or tuffwing pilot1211 Aircraft - Electric - Airplanes (FS/W) 1 Nov 10, 2011 04:18 PM
Discussion Smallish Wing/Delta/Pusher: Ritewing-Superfly-Tuffwing-MiniSlinger-HKParkjet roo_ster Flying Wings 3 Sep 27, 2011 09:03 PM
