Mar 25, 2012, 12:25 PM
Speedo Battery
After trying all types of batteries. Two types have worked out great. I like flying for several hours instead of several minutes. 330 mAh just doesn't do it.
3+1 pack AAA 1000 mAh batteries. With the new VERY heavy tailed fuse, you need 2.5+ oz of lead, which is tough to get in, but possible. Cost for 4 cells is $1.82, but no need for regulator. Add in plugs, wire, shrink, etc and you have about $2.00 per pack.
http://www.ebay.com/itm/200645924203...84.m1497.l2649
(2) TR 16340 1000 mAh with 5v voltage regulator Need 3 oz+ of lead, but there's plenty of room in the nose with these. They cost about $1.30 per cell, so you have $2.60 + $8 for voltage regulator. With wire, plug, shrink, etc. you have about $10.78 in the pack.
http://www.ebay.com/itm/110846489262...84.m1497.l2649
Mar 25, 2012, 12:52 PM
Old skool speed freak!
vinmech's Avatar
I made a pack with some 2/3rd AA 900ma cells I had laying around.
It was built with 2 laying end to end to go into the nose,and the other two vertically.
The 2 vertical cells will take up most of the front half of the canopy space.
A 8 gram servo for elevator right behind the battery, then Rx under wing saddle.
Mine balanced perfect with no additional weight!
I like the idea of using usable weight myself.
MR
Mar 25, 2012, 01:04 PM
Woodstock 1's Avatar
They don't seem to say anything about what chemistry these are?
Mar 25, 2012, 01:36 PM
The AAA cells are Nimh and the others are lion
Mar 25, 2012, 01:37 PM
MR
Do you have the original white fuse, or the very tail heavy grey one?
Discussion New version of speedo? Speedo Pro! slope junkie Slope 303 Sep 20, 2017 04:49 AM
For Sale Speedos $67.99 cody303 Aircraft - Sailplanes (FS/W) 21 Apr 08, 2012 11:37 AM
Discussion Speedo for sale cody303 Slope 10 Mar 10, 2012 10:23 PM
Help! Speedo Pro Mark II battery selection etc.???? fabmaster911 Slope 2 Mar 01, 2012 11:48 AM
