Mar 24, 2012, 08:49 PM
andione1983's Avatar
DEVO 8S and Walkera V200D03 3D questions
Hi guys i took out my Walkera V200d03 today, flew around for a while in Stunt mode, eventually picked up the courage to do the first flip, and to my shock the heli did not perform to my expectations, it too a long time to flip and very slow in negative pitch to pull up i nearly lost it in the trees... luckily i manage to right it just before hitting the trees, and saved it.. so question is if, who owns one and have you tried 3d? if so what settings do you use on the DEVO 8?
thanks in advance for any advice, of what i need to investigate..
Mar 26, 2012, 04:52 PM
V120D02S, GCP
LarsDennert's Avatar
Id be curious to learn more about this helicopter. I have seen youtube 3d of it and it performs very well. This guy is really knowledgeable
Walkera V200D03 Maiden Flight Windy Day (6 min 10 sec)
Mar 27, 2012, 10:37 PM
Apr 02, 2012, 03:47 PM
hmm not much info floating around for this heli... might pop over to HF
May 11, 2014, 08:33 PM
Hi my friend, I bought one V200D03 and I have the same issue you had. It's too slow for flip with default configurations.
Have you solved this??
May 14, 2014, 04:34 AM
Try moving your Endpoints or Travel Adj on your aeilon and elevator to around 110%.
I did this on my 450 and it helps spin it around and over faster. I actually have mine at 115% in my Tx. Also try to speed up your cyclic rates.
May 24, 2014, 07:30 PM
Hi my friend, thanks for your help.
I have success by changing ther Aileron/Elevator Ext at flybarless controller.
For who are with same problem as mine I suggest watch this video:
How to setup Walkera Mini Helis for 3D (7 min 57 sec)
It's for micro helis but adjusts are the same for v200d03.
May 27, 2014, 01:38 AM
https://www.youtube.com/watch?v=DQu4-fjmdTw
Try in micro forum for this heli.
May 29, 2014, 11:31 AM
IHW Heli Division
IntegrityHndywrk's Avatar
I can help with this heli. What is the current problem?
Jun 03, 2014, 07:37 AM
Hi my friend. Thank for you help but with that video I could solve my problem. Thank you.
Discussion Walkera V200D03+DEVO 8 6ch helicopter! one01 Micro Helis 1457 Jan 08, 2016 03:17 PM
Discussion Walkera Devo 8S TX and Telemetry Module WK CTL01-D i812 Micro Helis 141 Sep 24, 2014 07:57 PM
Discussion Walkera devo reciever question? autowarrior Beginner Training Area (Heli-Electric) 0 Feb 29, 2012 12:58 AM
Discussion Walkera V200D03 with DEVO 8 Transmitter, Upgraded 4F200LM oomodel.com Micro Helis 1 Aug 27, 2011 04:26 AM
