Mar 18, 2012, 09:23 PM
The Seer's Avatar
Thank for all your replies, it appears that the most import part of this not to put
too much weight in he PT boat, it would also appear that there is no set standard as to how you power your boat as long as you don't over power the model to the point of creating a jet plane.
Mar 22, 2012, 03:36 PM
"Damn The Torpedoes...."
PT-333's Avatar
I use two side motors with a center dummy prop that I remove before running.
Apr 12, 2012, 11:00 PM
Po' boys does w/ Po'boys ways
haxawsnavy's Avatar
Question if I may
Originally Posted by CaptCB
You do know, that Frank has a new fiberglass Elco hull AND deck. They do not need much framing, due to the good glass work. Put the weight into running gear, if you have to run 3 screws. CaptCB
Do you have any contact info for these products as I'm still kinda new here and am not sure who Frank is by this refererance..Thx Tm
Apr 12, 2012, 11:16 PM
I've got a 1/24 scale PT (proboat PT109) .. runs twin the "stock" 550 cans ... was "fast enough" stock
but I've made a few small changes... and I'm impatiently awaiting for the 35mm brass props
as for the weight I needed to ADD weight to my twin setup (by way of batteries... proboat said 2.. i've got 4 in there) to get proper waterline ..etc .. and it still gets up and hauls
Apr 13, 2012, 12:11 AM
CaptCB's Avatar
Who is Frank?
It is: Frank's Mosquito Boat Hobbies, the guy to go to, for 1/20th, and 1/16th, PT Boat models, and upgrade parts. He also has some parts for, or that will work on the 1/24 scale boats. CaptCB
Apr 13, 2012, 06:00 AM
Old wreck in Milwaukee
Prins Willem's Avatar
Franks Mosquito Boats: http://www.franksmosquitoboathobbies.com/
Wayne Traxel also has hulls & cabins available:
http://www.ptboatworld.com/PT_Boat_M...terprises.html
Apr 13, 2012, 02:33 PM
OhioMike's Avatar
3 motors is awesome!! 3 brushless motors and esc's will cost a fortune unless you get them at hobbyking. One shaft and motor was suggested more for simplicity than any other reason! Wayne traxel sells a lot of his hulls thru ebay by the way. They start at about 225.
Apr 13, 2012, 08:56 PM
The Seer's Avatar
Hi Everyone been away for awhile now I,m back. Thanks for all your replies
I have been in contact with Franks Mosquito Boats and bought most of the
parts I needed, I have also been busy developing some of my own gun kit
barrels for the 50 Calibre machine guns will be developing a barrel for the 40 mm Bofors gun also at a later date.
I hope to have the The OH Frankie PT Boat 309 in the water by the 1st of June.
The Seer
Discussion Got a PT Boat engine, but no PT Boat? Kmot Dock Talk 16 May 10, 2012 03:15 PM
For Sale ProBoat PT Boat P31 Boats (FS/W) 1 Feb 29, 2012 11:22 AM
Discussion Proboat Arleigh Burke vs PT Boat laser110 Scale Boats 8 Nov 19, 2011 10:20 PM
Link World War II PT-boat restoration reaches milestone, PT-305 ken_nj Dock Talk 4 Nov 16, 2010 08:12 AM
Discussion Last Pt Boat Pt-812 norgale Dock Talk 4 Sep 23, 2007 04:58 PM
