This thread is privately moderated by jrplane, who may elect to delete unwanted replies.
Mar 11, 2012, 09:54 PM
Trader Rating: 248
Fast is good
jrplane's Avatar
For Sale
Power supplies 12v or 24v plug and play
12volt 47 amp 564 watt,
24volt 47 amp 1130 watt.
At 110 volt
I am using two in series for 24v on my lab 8, they are very stable, rock solid, These are re-purposed server power supplies. There is no voltage drop under load.
They are set up ready to go with 4mm outlets and power cords.
Single 12v-12"x2"x3"
Double24v-12"x4.5"x3". Under 7 pounds
These have the DC ground floated! Many being sold here do not. They have the AC removed, which is not safe.
These power supplies can be run from a single household circut, they are very efficent >99 %
Heres a close up of the bussiness end of the power supply.
You can see the 24v model is wrapped in black, comes with jumper to allow 24V. as you can see you can use 2-12v and 1-24v at the same time. 2-12v top row , 24v bottom row, or remove the jumper and you have 4-12v outlets. With the jumper in place you also can use the out two far out side connections for two 24V outputs. These power supplies are rated at 47 amps. I have personally abused my test setup, just to see where the fail point is. I have had my Lab 8 with 6-5000 3S @ full 40 amp charge and a cellpro 10 with 2-5S running wide open. I'm still using this power supply with no problem. Just because I did this for testing purposes,,,,,,,,,
I DO NOT RECOMMEND GOING OVER RATED OUTPUT!!!
Singles are 12v and white $55 shipped priority with conformation
Doubles are 12v and 24v and black $110 shipped priority with conformation
These are 100% ready to use. Plug and play.
I will ship out of the country.
Mar 13, 2012, 07:01 AM
Trader Rating: 1
are these 110 or 240?
Mar 13, 2012, 07:29 AM
Trader Rating: 248
Fast is good
jrplane's Avatar
110 volt
Mar 13, 2012, 05:24 PM
Trader Rating: 14
How Many watts for the 12v and 24v? And I asssume the 24V can do 2, 12v chargers at the same watt as just one 12volt?
Mar 13, 2012, 06:21 PM
Trader Rating: 248
Fast is good
jrplane's Avatar
I think I understand what you are asking 12@47amp-564 watts
A 24v@47amp-1130 watt
If you plug a 2-12v chargers into a 24v'er You will have 47amps of output to each charger.
Most charger list output watts not input watts. 47 amps is more than any 12v charger requires that I know of. Most requiring a lot of power go to 24v.
I hope I answered your question.
Mar 14, 2012, 10:25 AM
Trader Rating: 0
Just recieved my power supply to give life to my Hyperion DUO 500wx500w charger!!!!
Jeff knows his stuff!!!! The power supply looks great and he provided great customer service.... A+++++ across the board!!!!
Thanks Jeff!!!
Mar 14, 2012, 09:39 PM
Trader Rating: 23
pajonate's Avatar
Hi, all.
Just to share my experience with this product. I have the 12V one from Jeff. It came fast, Jeff was helpful in answering some questions I had for him, and the item works great. I am using it with 1 Q6 charger that can charge 4 6s batteries at once, 50W per channel, and I think 6A per channel (24A total) and one FSA charger on the other power supply channel.
I have tried it so far with 3x3s 2200MAh batteries at once and there is no problem in providing the power at all.
Soon enough I will try it with something more. I have 2 4S 4000mAh batteries that I will use.
Jeff, Take care, and good luck with your future sales.
Mar 16, 2012, 12:23 PM
Trader Rating: 53
USN (retired)
flymustangs's Avatar
Do you isolate the AC or DC ground on the second P/S for a 24V setup?
Mar 16, 2012, 12:34 PM
Trader Rating: 248
Fast is good
jrplane's Avatar
The DC ground is isolated
Mar 16, 2012, 11:48 PM
Trader Rating: 781
Indoor Free Flight Modeler
I would like this:
Please PM paypal info.
Mar 17, 2012, 07:17 AM
Trader Rating: 248
Fast is good
jrplane's Avatar
PM sent, thanks Don
Mar 17, 2012, 07:27 AM
Trader Rating: 781
paypal sent
Don
Mar 17, 2012, 09:14 PM
Trader Rating: 0
got the12 it works great going to get another 12 so I can have 24 v
if any one needs a power supply here is where to buy them
I have bought stuff from outher sellers and have had great results
and jeff is no exception hes great to deal with
and got what I paid for quickly if you need a power supply here is the place
to get it.
Mar 20, 2012, 07:29 PM
Trader Rating: 177
I fly 3-C Crash,Crunch,Crumble
Mr. foambuilder's Avatar
Jeff; Do you have a single available? Pls send PP info. Roy
Mar 20, 2012, 07:32 PM
Trader Rating: 781
Talk about fast delivery, ordered Saturday and it arrived in Monday's mail!
Don
For Sale Power supplies, 500w or700w @ 12v, 1000w or 1400 watt @ 24v paulpeffly Aircraft - Electric - Batteries & Chargers (FS/W) 1 Apr 30, 2016 03:58 AM
For Sale Power supplies/Custom Charging setups, 500w or700w @ 12v, 1000w or 1400 watt @ 24v paulpeffly Aircraft - General - Miscellaneous (FS/W) 0 Jan 24, 2012 12:03 PM
For Sale Power supplies/Custom Charging setups, 500w or700w @ 12v, 1000w or 1400 watt @ 24v paulpeffly Aircraft - Electric - Batteries & Chargers (FS/W) 0 Jan 24, 2012 12:01 PM
For Sale Power supplies/Custom Charging setups, 500w or700w @ 12v, 1000w or 1400 watt @ 24v paulpeffly Aircraft - Electric - Batteries & Chargers (FS/W) 0 Jan 20, 2012 10:52 AM
For Sale Power supplies, Custom Charging setups, 500w or700w @ 12v, 1000w or 1400 watt @ 24v paulpeffly Aircraft - Electric - Batteries & Chargers (FS/W) 0 Jan 09, 2012 04:34 PM
