This thread is privately moderated by RightBrother, who may elect to delete unwanted replies.
Mar 09, 2012, 01:40 AM
New Plane Project - X-45WL
Started working on airframe of my first design. Copy of X-45c silhouette and using the wing design of the Blucor Wing and reinforced with internal wooden rods so the nose shouldn't get crushed.
This delta wing is kind of a hybrid airfoil and step combined.
About ready for the electronics which are on order. Won't take long to finish it but may have to wait for better weather to maiden, lots of wet snow on the ground.
Used TLAR measurement system.
Dimensions:
chord: 47 cm
wingspan: 66 cm
width of wing: 1.5 cm
cg: from 22.5 to 25.5 cm
Have no idea if it will fly or what flight characteristics may be but sure is fun finding out.
Updated 3/17: photos of motor mount I made of aluminum and showing XXD (Mystery motor I think) A1510 2200kv motor I plan to use with 5 inch prop. Motor mount is about 9 grams, a little heavier than wood but I got tired of breaking mounts.
Updated 3/18: finished plane, ready to maiden. Craftsmanship is quite not existant, kind of kluged together. AUW is 240 grams. Portly but I like some weight as its pretty windy these days around here. Going to use 500 3s lipo.
CG is around 26 cm from nose if I used the cg program correctly. Glides on my bed ok. I think it might be nice to add a piece to cover the electronics but don't know how to do it.
Updated 3/21: have had 4 flights now and I can handle it very easily in no wind but in blustery conditions I lose control. Crashed it pretty severely on 3rd flight so replaced center section (took 5 minutes) and put motor mount on top. Hopefully in a severe crash it will just break the zip ties that hold the motor mount to the airframe.
Updated 3/24: have changed motor mount to use foam and zip ties.
X45WL Delta RC Foam Wing (1 min 28 sec)
Updated 3/29: latest flight
X45WL Foam Delta WIng #7.avi (1 min 17 sec)
Updated 4/1: put a vinyl cover over electronics. Yeah, looks like a bikini.
Updated 4/12: have moved electrics to another project plane. Lessons learned: this plane flies like a little jet. I think I will build a new one later but just use a kf step on top to simplify construction and scale it up 25%. Then I think it will be easier to control, have a better glide and save the nose a few bruises.
All in all it is a good design and I will continue working on it.
Update 6/2: Will build this again with laminated 9mm EPP. I am done with foamboard. It is just too fragile for wings if you like to bash them.
Last edited by RightBrother; Jun 01, 2012 at 05:25 PM. Reason: Update with motor mount
Mar 09, 2012, 11:31 AM
cytochrom's Avatar
that will look great when finished. it looks good now
Build Log Giant scale X-2 project! X30PILOT Rocketry 273 Sep 07, 2023 04:22 PM
Discussion New Project Idea? 2 Meter Foam F3A Plane :) Team3D Foamies (Scratchbuilt) 7 Jun 22, 2012 10:28 AM
Discussion critique my power choices for this project plane Meach_in_GA Electric Power Systems 6 Mar 06, 2012 08:57 PM
Build Log Project Bipe-X New Videos!!! 3Deranged 3D Flying 74 Dec 29, 2008 05:07 PM
Project X-37 Plane Timbo337 Parkflyers 2 Jul 12, 2004 09:14 PM
