Old Mar 04, 2012, 01:15 PM
fmkit is online now
Find More Posts by fmkit
fast
fmkit's Avatar
Cool
Easy pan tilt
I'm able to control multiple cameras and flying wing with just two fingers
small button used to set presets, Z button(1s click) to store position, if elevator pulled hard while joystick used t pan/tilt plane control re-gained, camera left at current position, if I click small button once camera set at 1st position (centered) and joystick controlling plane.
just uploaded video:
http://youtu.be/zdh5GKrZNRA
the wing
Old Mar 05, 2012, 08:00 AM
alexedit is offline
Find More Posts by alexedit
alexedit's Avatar
Very cool!!
Old Mar 06, 2012, 05:04 AM
fmkit is online now
fast
fmkit's Avatar
if there is interest I can offer small device ($25?) that you connect PPM while on ground to store P/T presets then while in flight use 3-position PWM to switch preset in the same fasion - regardless of servo speed camera will move smooth without jitter , 1st preset at 2x speed (camera center position) , all servos are usable and can be stretched to almost 180degree (no mods, no soldering resistors inside)
Wanted XAircraft CM130-TPS Pan/Tilt Camera Mount Guntars Aircraft - Electric - Multirotor (FS/W) 0 Mar 03, 2012 09:07 AM
Wanted ReadyMadeRC Easy Star pan/tilt pod Casey_S FPV Equipment (FS/W) 0 Jan 23, 2012 02:18 AM
Discussion Best Pan Tilt, Best pan tilt servos??? justind123 FPV Talk 19 Feb 26, 2010 09:42 AM
For Sale Easy Star FPV Pan / Tilt System crd Aircraft - General - Miscellaneous (FS/W) 27 Jan 13, 2010 11:18 AM
Discussion Easy Glider Pro Canopy Mod for Pan & Tilt Njoro FPV Talk 11 Sep 13, 2009 07:30 PM
