Mar 02, 2012, 08:12 AM
who put that tree there
dazza44's Avatar
Question
sea fury 480 esc ??
im in a build of this..
4 servos on control surfaces,2 servos for retracts.
motor installed.
question is the esc. i have a 40 amp switch mode,a 40amp with built in bec and seperate 5a bec unit.which one do i use the switch mode or the one with seperate bec.
thanks
daren
Mar 02, 2012, 02:54 PM
An itch?. Scratch build.
eflightray's Avatar
If you're worried about BEC overload, how about the ESC with bec for the control servos and the standalone bec for the retracts. Retracts have been known to jam slightly if a leg gets 'misaligned', and that could draw a much higher current.
I have set my Spitfire up that way. Just common the negatives, and use the standalone bec positive to the retract servos.
Mar 02, 2012, 02:58 PM
dazza44's Avatar
thanks shall wire bec to retracts..
dont fancy a cooked esc..
Question sea fury 480 esc ?? dazza44 Electric Warbirds 0 Mar 02, 2012 03:12 AM
Sold Rare Direct Connection Sea Fury NIB imodel Aircraft - Fuel - Airplanes (FS/W) 0 Mar 01, 2012 09:18 AM
Sold E-Flite Sea Fury w/ E-Flite 480, Retracts, and Hitec Servos. LPU Only lafuerza Aircraft - Electric - Airplanes (FS/W) 1 Jan 19, 2012 10:23 PM
Sold E-flite NIB Hawker Sea Fury/esc/park 480 Eplane Aircraft - Electric - Airplanes (FS/W) 2 Dec 27, 2009 08:38 AM
Sold NIB E-flite Sea Fury with ESC, Motor and servos! Receiver Ready! bighead93 Aircraft - Electric - Airplanes (FS/W) 15 Apr 05, 2009 06:40 PM
