Zinger prop question?? - RC Groups
Feb 24, 2012, 01:35 PM
AMA 1034020
ATCH's Avatar
Question
My buddy give me a 16x8 Zinger wood prop. Are all Zinger's for Gas/nitro? Or can they be used on a electric motor?
Atch
Feb 24, 2012, 01:47 PM
jrb
jrb
Member
jrb's Avatar
YMMV -- that was the worst prop I ever tried on my 1/5 E Cub -- APCE 16x8 was much better.
Feb 24, 2012, 02:14 PM
Ken Myers's Avatar
My bearded flying buddy uses Zinger Props as prop blanks, as they are easier to modify than carving a whole new prop, but the man really knows what he's doing. I cannot recommend it for others!
They are usually the worst choice and usually draw a lot more amps. You can try anything you like, and it will work, but you will probably find that other brands of 16x8 props will drop your amp draw and still give you the type of flight performance you desire.
Feb 24, 2012, 05:25 PM
Atch
They would work on electric too. Tried one on my 89" AJ Slick electric but the performance was not as good as other brands.
Feb 25, 2012, 12:30 AM
Doug Bartley's Avatar
Nitro props are and can be used on electric, but props designed for electric work better.
Try the Zoar electric wooden props, can't be beat in my book!
I also am quite satisfied with the electric Hawk propeller I purchased from SDS Hobbies, about 40% cheaper than Zoar, but well made. FWIW Doug B
Feb 25, 2012, 09:11 PM
Zinger props were and continue to be best of breed in Wood props. These at least have accurate pitches APC's do not.. imo those things cheat.
Don't believe ? Measure them.
Having said that, Zingers (as is) are less than ideal on electrics... with out a reprofile/reworking.
Buy/build a decent prop gauge and learn .. a lot :-)
Feb 26, 2012, 02:36 PM
Senile Member
Lnagel's Avatar
I'm sorry, Bare, but that just doesn't make any sense to me. If Zinger props are so fantastic why do they need a "reprofile/reworking" for electrics? It's not as if they know if they are being spun by an IC engine or an electric motor. Or am I missing something?
Larry
Help! Zinger Prop Balance.. storm2313 Engines 7 Nov 15, 2011 11:23 PM
Sold 26x12 Zinger wood prop NIB $20 shipped Daveyboycfs Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jul 26, 2011 10:06 PM
Discussion Zinger Prop FlyFisch Fuel Plane Talk 15 Mar 28, 2011 07:47 PM
unicorn brushless prop zinger????? asjeep Power Systems 2 Jul 22, 2004 11:56 PM
Is a Zinger wood prop a good slowflier prop? WickedFunRC Power Systems 7 Feb 09, 2003 11:22 PM
